rpo codes help
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
rpo codes help
hey i have several rpo codes that don't show up on the decoder if anyone knows what they are please let me know
b3w 8ph e7z fa1 fa2 ga1 ga2 p06 9ph 968
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: rpo codes help
http://cs.pontiac-club.com/graphics/...-car-codes.pdf
RPO Decoder
Results
GA1
FLEET INCENTIVE THE ALDERWOODS GROUP (C/H/K/U/W-TRK CKGML)
GA2
FLEET INCENTIVE ECHO STAR/DISH INSTALLATION NETWORK (TRK CKG)
B3W
TEST WATER - DELETE
8PH
COMPONENT RR LH COMPUTER SEL SUSP (8PH)
FA1
AXLE REAR 12,000 KG, DUAL SPEED, 4.88:1 / 6.94:1
FA2
AXLE REAR 14,000 KG, DUAL SPEED, 4.88:1 / 6.94:1
9PH
COMPONENT RR RH COMPUTER SEL SUSP (9PH)
Codes not found:
PO6
968
New codes are added on a routine basis. Check back later.
Searching [18467] Codes
General Motors RPO codes give insite as to what options/features the vehicle originally had. They can be found usually on
RPO Decoder
Results
GA1
GA2
B3W
TEST WATER - DELETE
8PH
FA1
FA2
9PH
Codes not found:
PO6
968
Engine: 310"
Re: rpo codes help
RPO Decoder
Results
GA1
GA2
B3W
TEST WATER - DELETE
8PH
FA1
FA2
9PH
Codes not found:
PO6
968
RPO Decoder
Results
GA1
GA2
B3W
TEST WATER - DELETE
8PH
FA1
FA2
9PH
Codes not found:
PO6
968
Re: rpo codes help
The problem is many of those decoders group all GM RPO codes together despite GM reused many of the RPO codes for different years with different definitions.
The first two on the list, alone, aren't quite applicable.
RPO Decoder
Results
GA1
GA2
B3W
TEST WATER - DELETE
8PH
FA1
FA2
9PH
Codes not found:
PO6
968
RPO Decoder
Results
GA1
GA2
B3W
TEST WATER - DELETE
8PH
FA1
FA2
9PH
Codes not found:
PO6
968
Transmission: 5-Speed Manual
Re: rpo codes help
Yep Thats's The Problem With A Lot Of These Decode Sites ,The Codes May Stay The Same But The Definitions May Change Over The Years.
Engine: 5.0 EFI
