RPO Codes Link to decode your Service Parts Identification label
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
Below is a cool site I found to decode the Service Parts Identification label in the glove box or under the spare tire cover. Just click on the left side choices. I was able to verify the options on a car I am thinking of buying.
http://www.rpocodes.com/
Re: RPO Codes Link to decode your Service Parts Identification label
That site is using the same RPO code list that every other site listing codes has. The problem with that is that GM reused RPO codes over the years and when you see (91), they are specific to '91 only. RPO 86A is the black/silver stripe on the IROC-Z from 1985-1990. If you look at this list, it shows different colors. The code was reused because the Camaro wasn't using the black/silver stripe beyond 1990, so it was reused.
Good point that you make. Look at the (1C5) RPO that is commonly known in 3rd gen circles as the California Iroc used only in 1985 has now become a 4 cylinder, 5.7 c.i. Isuzu on this new list.
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Went to that site.
Noticed a list to help find build sheet. Are these suggestions good for 3rd gens as well?
To find your build sheet and/or options label, you'll need to look at one or more of the following locations in your vehicle...
1) inside the trunk lid
2) in the back seat bottom cushion springs
3) sealed and attached to the top side of the fuel tank
4) inside of the glovebox door
5) under the hood
6) underside of the dash pad
7) under the front seat carpet area
5) under the hood
Yes, and you might find it under the carpet in the rear footrest area... or you might never find it at all. Of all my cars I have never found one.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Mine's must be sealed on top of the fuel tank,
I've never found one in my car!!!!
hectre13
Dec 11, 2023 08:14 AM
