Formula / TA ?
Old Oct 4, 2012 | 04:49 PM
jrmartino78's Avatar
Car: 88 Firebird Formula
Engine: 350 TBI
Formula / TA ?
I was just wondering what exactly is the difference between the 88 formula and the 88 Trans Am? Most of all I've seen is that the only real difference is like the dash and small options. But nothing precise.
Old Oct 4, 2012 | 04:57 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Formula / TA ?
I would be able to tell you for sure if I had my parts cd or my historical book in front of me.
In general the Trans Am get ground effects. I believe the Trans AM uses a bumper without the slots cut for the inserts, while the Formula has the inserts. The TA also has the flat hood with 2 vents while the Formula has a "tear drop" or "power bulge" hood.
Old Oct 5, 2012 | 09:49 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Formula / TA ?
Yeah the Formula does not have the GFX, in fact it has differant bumper covers, the wheels are differant, hood is differant like stated above. Mechanicaly they are really the same. I like the looks of th TA better, but the Formula does have a nice simple look to them.
Old Oct 5, 2012 | 11:56 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Re: Formula / TA ?
The Formula is basically a Firebird body with the Trans Am goodies like engine, suspension, brakes etc. Exterior is the same as a Firebird except for the hood with the power bulge, wheels and the Trans Am's wrap-around spoiler. Taillights and facias are the same as in a Firebird. The idea was to make a Firebird that performed as the TA but costs less. The advantages of the less appointed Formula is that weight is lower than that of the TA so performance should be marginally better, given the same powertrain is chosen.
Old Oct 14, 2012 | 07:49 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Formula / TA ?
I think the Trans Am had additional sound insulation as well... Think...
Old Oct 15, 2012 | 06:23 PM
xcalibur's Avatar
Car: '95 Impala SS
Engine: 350/LT1
Transmission: (Sold my '89 Formula 350)
Re: Formula / TA ?
Yep, my '89 Formula 350 weighed in at 3262 lbs. The T/As are closer to 3400 lbs.
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
