how many different clusters
Old Oct 26, 2012 | 10:16 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
how many different gauge clusters came in the 85 camaros.I got a s/c and a berlineta.So I know for sure the 85 speedo type and the digital type in the berli.I'm wanting to take the 305 carb engine out of the berli and put it into the s/c.the ecm and engine harness have to go into the s/c.Question?will my stock gauges work in the s/c when I put the 305 ecm and engine in.Or do I need to find a different gauge and cluster harness.I dont really want the digital cluster in it if I can get a standered cluster.would perfer a 110 or higher.I got a 110 out of a 90 camaro rs.Now if I can plug and play my 85 cluster I will do that!!!!
Old Oct 26, 2012 | 10:58 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
Re: how many different clusters
There are 2 different styles of clusters in 3rd gen camaros.
82-89 <- mechanical speedo
90-92 <- electric speedo
You can swap a 90-92 style cluster into a 82-89 camaro, but it is alot of work. The dash is different. The cluster mounts different. The connectors are different. The speedo is different. There is some custom fab involved. Do a search, there are a few threads about it.
--edit--
as far as 85, I believe there is 4 different clusters?
Berilenta digital
base w/ idiot lights
full gauges w/85mph? Speedo
full gauges w/110mph? Speedo
Im sure someone will know the different speedos. I think you can swap just the speedo in that cluster? Someone with more knowledge on that would need to verify
Old Oct 27, 2012 | 07:53 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
thankyou!anyone got more?
Old Oct 27, 2012 | 09:43 AM
yo soy el warg's Avatar
--edit--
Berilenta digital
The one thing I can add to this is that the full gauges w/110 mph were not on any 1985. The other three you listed were on them.
Old Oct 30, 2012 | 10:06 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
We had the 85 berli running the other day.It's smoking and has some blow buy.But no knocks or tics in the block.I did like the gauge cluster after I sean it in action.I got a 84 with a set I don't know if they work or not.may put them in and see how they do.
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
