Tune Up after 5 years
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7 350 TPI
Axle/Gears: 3:23
I recently got my GTA its all stock has 132k miles the question i have is will a tune up consisting of and oil change oil filter / transmission flush / and coolant be ok to make the car a DD or do i have to do everything in this list?
https://www.thirdgen.org/tpimod1
my other question is should i buy performance spark plugs oil filter fuel filter spark plug cables or should i buy normal one does it matter ? because i have 0 performance or power adders on the car.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Tune Up after 5 years
I always use the OEM plugs and then get whatever wires I want. I put the AC Delco copper tip's in my TA with Taylor Street Thunder wires, MSD cap&rotor, AC Delco PVC, and fuel filter. I put a K&N air filter in the stock air box. A coolant flush, trans service and rear diff service is a good idea as well, but if the trans has never been serviced sometimes when you done one at high miles it can make problems.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i would run A/C delco plugs that it should call for it by the book. and dont buy junk oil or oil filter. as far as trans, i would do a trans flush, then a trans service. (service is mainly for the filter change, and flush is mainly to remove all old fluid with new fluid, including torque converter). k&n air filters are always nice but very pricey. fuel filter i would go with delco as well. cap rotor, wires, same. i would try to find a cap with brass nipples terminals though
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I have the same situation and this is my list
1. Engine Oil + Filter
2. Transmition Oil + Filter
3. Coolant
4. Differential Oil
5. Brake Fluid
6. Power stering Fluid
7. Spak Plugs
8. Spark Plug Cables
9. Rotor + Ignition Cap
10. Ignition Coil (This coul be optional for you)
11. Check Brakes
12. Repack Weel Berrings
13. Grease all fittings uder the car
A.Tierods
B.Pitman
C.Ball Join
D.Universal Union of dive shaft
14. Check sterring components
15. Check all rubbers under the car
A.Engine Mount
B.Sweybar endlinks/Mounts (Front/Rear)
C.Bump Stop
D.Control Arms bushings
16. Check Shock Absorbers (I'm replacing them)
17. Check al hoses for detriment if they have replacethem.
With this list it is my intention to take the car back to stock New condition because most people dont care for some mantainance I prefair to do all of them when I get an use car so I know that I did all their is to do fron day one and then I don't get sorprices on the road.
3. Coolant
4. Differential Oil
5. Brake Fluid
7. Spak Plugs
11. Check Brakes
A.Tierods
B.Pitman
C.Ball Join
A.Engine Mount
C.Bump Stop
Engine: 5.7 350 TPI
Axle/Gears: 3:23
Thx guys
how about for the distributor cap & rotor do i get external or internal msd?
http://www.autozone.com/autozone/par...mString=search
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No need for an expensive red distributor cap that doesn't provide any benefits over a quality regular replacement. Cap cannot be seen under the TPI cover anyway. You want a Standard DR468 cap and DR326 rotor.
Change the serpentine belt, it's not on your list.
Don't bother with the pitman arm, it will be in the same condition after one million miles as it is when brand new. It doesn't have any moving, wearable parts.
Engine: 4++,350 & 305 CIs
I'm not a fan of the trans flush. Just change the filter and add the lost fluid. The dealer flush system moves fluid backwards thru the trans and can put junk in places it shouldn't be. (seen it to many times).
Its kinda like changing fish tank water, change a little bit at a time or the fish may die.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1992 RS
Transmission: Automatic
I'm glad this thread has come up. My 92 camaro has basically sat for the last year since I haven't had the money to give it the alignment and new tire its needs.
Before that it ran like a CHAMP, but Since that time the engine has started to run pretty rough. I'd ideally like to get my car into a state of daily driver reliability, which honestly it always was... but it does need a little loving atm.
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Here is a good cap and rotor kit, should be under 30$ http://www.autozone.com/autozone/par...6_385786_2267_. Then bosch plugs, and I think autolite plug wires IIRC, I can look it up when I get home
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
