Bolt Sizes Needed: Distributor Cover and Fuel Rail
Car: 1989 GTA
Engine: 5.7 w/Paxton
I was wondering if anyone knows the sizes. I have looked through my bin and nothing is in there that will work for the 3 to the dist. cover. I also found that the bolt holding the fuel rails to the front of the intake is missing. Appreciate any help on sizes. Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Bolt Sizes Needed: Distributor Cover and Fuel Rail
IIRC the extension is 4mm fine thread, the front fuel rail is the same thread as the dizzy hold down 3/8-16 .
Car: 1989 GTA
Lol...I knew you would post the answer. Thanks again!
Engine: Lb9
Transmission: M20
I hope I remembered correctly
Car: 89 Iroc Convertible
The dist cover uses 3 T-20 torx head screws.Not sure what you could use in place of them
knight72
Aug 10, 2015 09:32 PM
