Trying to determine trim
Old Jul 25, 2014 | 06:11 PM
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
I'll just get right to it. So I'm looking at buying another Camaro. It's listed as an 88 RS. I'm in Canada and noticed the RS was only available in select states. So I've been trying to do some homework to determine if it is indeed an RS, or just a sport coupe or maybe even something more (I noticed a Z28 rpo). I went to GM and had them email me the rpo list for that car. So here it is. Any help and insight is appreciated.
11Q = MOLDING COLOR,WHITE MOLDING COLOR(11Q)
15P = WHEEL COLOR,MEDIUM SLATE GRAY WHEEL COLOR(15P)
40U = EXTERIOR COLOR,PRIMARY EXTERIOR COLOR(40U)
6DB
7DB
829 = SEAT BELT COLOR - MED DK GRAY SEAT BELT COLOR(829)
82C = TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY CLOTH TRIM
COLOR(82C)
82I = INTERIOR TRIM,MEDIUM DARK GRAY INTR TRIM COLOR(82I)
8NL
90A = ACCENT STRIPE,TWO-TONE,SILVER/YELLOW STRIPE
COLOR(90A)
9NL
A01 = WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01)
A31 = WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
A90 = LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC
RELEASE ELEC REL LID LK(A90)
AC3 = ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR
D/SEAT ADJR(AC3)
AG9 = ADJUSTER,SEAT,6-WAY POWER 6-WAY PWR ST ADJR(AG9)
AM9 = SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK
R/SEAT(AM9)
AR9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL
RECLINING(EUROPEAN STYLE) DELUXE MANUAL RECLINING FRONT
BUCKET SEAT(AR9)
AU3 = LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
B18 = ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18)
B34 = COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR
COORDINATED) FRT CPT INS FLR MATS(B34)
B35 = COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR
COORDINATED) RR CPT INS FLR MATS(B35)
B48 = TRIM EQUIPMENT,LUGGAGE COMPARTMENT(DELUXE) LUGG COMPT
TR(B48)
B6Q = PACKAGE,DECAL,TURQUOISE DECAL PKG(B6Q)
B84 = ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI
MLDG(B84)
C41 = HEATER,OUTSIDE AIR,WITH FAN AND DEFROSTER OUSIDE AIR
HTR W/FAN & DEFROSTER(C41)
C49 = DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C95 = LAMP,INTERIOR,ROOF COURTESY AND DUAL READING DM &
READING LP(C95)
CC1 = ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
CD4 = WIPER SYSTEM,WINDSHIELD,PULSE PULSE WPR(CD4)
D34 = MIRROR,INSIDE,SUNSHADE S/S MIR WITHOUT
ILLUMINATION(D34)
D7L
D80 = EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED
RR SPLR(D80)
D88 = STRIPE,SPORT SPORT STRPE(D88)
DG7 = MIRROR,OUTSIDE,RH & LH REMOTE
CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
E5Z
E7Z
E9Z
FE2 = SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH Z28)
RIDE & HANDLING SUSP(FE2)
G80 = AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION
L/SLIP R/AXL(G80)
GU4 = AXLE,REAR,3.08 RATIO 3.08R(GU4)
J42 = BRAKE SYSTEM,DRUM(ALUMINUM) AL BRK SYS(J42)
J50 = BRAKE SYSTEM,VACUUM POWER VAC PWR BRK(J50)
JG1 = SHAFT,PROPELLER(ALUMINUM) AL PROP SHF(JG1)
K05 = HEATER,ENGINE BLOCK ENG BLK HTR(K05)
K34 = CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K68 = GENERATOR,105 AMPERE 105 AMP(K68)
LB9 = ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9)
M39 = TRANSMISSION,MANUAL 5-SPEED(BORG-WARNER) 5-SPD
M/TRANS(M39)
MM5
N33 = STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N64 = WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY
SPARE(ALUM)(N64)
N96 = WHEEL,16X8,CONCAVED,FIVE BLADE,PAINTED,INCLUDES
CENTER INSERT AND LOCKING NUTS(ALUMINUM) AL WHL(N96)
NA5 = EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL
EMIS(NA5)
NP5 = STEERING WHEEL,LEATHER WRAPPED(USED WITH Z28,RS
PACKAGE 1A1) (NP5)
PB4 = LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4)
QDZ = TIRE,ALL P245/50VR16/N BL R/PE ST TL HW4 TIRE(QDZ)
T93 = LAMP,TAIL AND STOP(SPECIAL)(USED WITH Z28) SPECIAL
TAIL & S/LP(T93)
T96 = LAMP,FRONT FOG(USED WITH Z28) FRT FOG LP(T96)
TR9 = LAMP GROUP,COURTESY LP GRP(TR9)
TT4 = HEADLAMPS,TUNGSTEN QUARTZ HALOGEN HALOGEN HDLP(TT4)
U25 = LAMP,INTERIOR,REAR COMPARTMENT COURTESY RR COMPT CTSY
LP(U25)
U26 = LAMP,INTERIOR,ENGINE COMPARTMENT COURTESY E/CMPT CTSY
LP(U26)
U29 = LAMP,INTERIOR,INSTRUMENT PANEL,COURTESY I/P CTSY
LP(U29)
U75 = ANTENNA,POWER(CHROME) PWR ANT(U75)
U79 = SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE
PACKAGE SHELF 4 SPKR SYS(U79)
UA1 = BATTERY,HEAVY DUTY HVY DUTY BAT(UA1)
UQ1 = RADIO,PROVISIONS FOR STEREO STEREO RDO
PR0VISIONS(UQ1)
UX1 = RADIO,AM/FM
STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO
AM/FM W/CASS & EQLZR(UX1)
V73
VAN
VK3 = LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG
PKG(VK3)
W62 = AERO PACKAGE AERO PKG(W62)
WW1 = AERO PACKAGE(WHITE)(USED WITH AERO PACKAGE W62) AERO
PKG(WW1)
X07
YR1 = SEAT,FRONT(CUSTOM) CUSTOM ST(YR1)
YS1 = SEAT,REAR(CUSTOM) CUSTOM RR ST(YS1)
YT1 = BUILD-UP,CUSTOM DOOR AND QUARTER CUSTOM DR &
QUARTER(YT1)
Z28 = SPECIAL PERFORMANCE PACKAGE,IROC-Z(MERCHANDISING
OPTION) IROC-Z PKG(Z28)
Z31
Z49 = MANDATORY CANADIAN BASE EQUIPMENT
MODIFICATIONS(CANADIAN) CANADIAN(Z49)
Old Jul 25, 2014 | 06:30 PM
Re: Trying to determine trim
Doesn't look like a RS.
Looks like a fairly typically optioned Z28; nice enough car, but nothing extraordinary.
Ignore the ad copy. Don't argue with the owner about what it is. Don't even bother bringing up the subject. Either buy it or don't, according to whether you think what you see is worth what you'll have to pay to get it.
Old Jul 25, 2014 | 07:25 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Their Were No Z28's In 1988,Only Sport Coupe's And IROC-Z's.
Old Jul 25, 2014 | 07:33 PM
Exactly: all the Z28s got the IROC pkg for acoupla years, as described in the above RPO list; unlike earlier years where the IROC pkg had the additional RPO B4Z. I guess GM was getting their money's worth out of paying IROC to license the name.
Z28 = SPECIAL PERFORMANCE PACKAGE,IROC-Z(MERCHANDISING OPTION) IROC-Z PKG(Z28)
Old Jul 25, 2014 | 08:32 PM
So what I gather it's a Z28 (or IROC-Z28) as that's what they called them in 88?
Old Jul 25, 2014 | 08:54 PM
Would appear that way, assuming the VIN is correct... RPO codes do not lie.
Make sure the VIN on the vehicle you are looking at - in ALL the places the VIN is stamped - matches the VIN you looked up.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
