1986 GM/Players Trans Am
Thought I would start a thread to document my car and its return to the road. The car has been sitting for many years so it will need a complete going over but fortunately I have alll the parts and even the rare parts that should have been returned at the end of the season. I will start the thread with a picture of the car when I picked it up and when it was new, hopefully when its all done it will look like it was in 1986.
Engine: 4++,350 & 305 CIs
Re: 1986 GM/Players Trans Am
Nice, It'll be very cool when done..
Axle/Gears: 10 Bolt 2.73 Open
Interesting car. I don't know anything about these cars. I look forward to learning more about them following this thread.
Here is a photo of the race seat used in the series. It was kept stored away with a plastic cover. Its a bit dusty but a good vacuum and brush should bring it back to new.
Here are some photos of the Brembo front brakes, adapter brackets and spindles. Zoomed in on the stamping number on the adapter bracket in case that helps anyone.
Yes I think it was a 12" from what I have read, I have some rotors in a box(I have lots of boxes and milk crates full of parts to go through-see cube van and the car was packed as well!!) that I will try and dig out and see what size and if any stamping numbers.
Do I spy gatorback tires in there? and would you happen to have another set of the calipers?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Great find! Did some racing team have this in storage or was this abandoned in a storage unit or something?
I have 2 sets of wheels and Gatorbacks. The one set was on the car and they are completely cooked. The spare set holds air but haven't checked them to see how badly cracked. I haven't checked the car to see what calipers are on it but teams only got one set so I would think they are the stock ones on the car. Now I need to go check!( Stock ones on the car)
The owner had the 1986 Trans Am and an 1987 and 1988 Camaro from the series and kept everything. Another member on the site bought the 87 and 88 and this car was sitting outside for most of it life. Looks rough at first glance but has a ton of potential and all parts are there and like new due to it having just 3800KM. Ill keep the pictures coming as this is a true time capsule.
I have added the 1986 series recap video to YouTube. "1986 GM/players" should bring it up. I will add link later tonight. Enjoy!!
Link....
Link....
My car shows up at 9:21 sideways!! The car also set fastest lap during the race on lap 9 according to the race printout sheet I have.
That's so freaking cool Munyguy! Thanks for the link on the video! I love automotive history. Especially the history of our Thirdgens! Hope the progress with your player's car becomes a successful one! I would love to someday build a reproduction thirdgen racer to mimic the player cars. Hopefully with guys like you restoring your vehicle, it can give me a guide map on building one. Keep us posted on your build!
Just watched that whole video Munyguy. Awesome piece of history, that I knew virtually nothing about. Thanks for posting that.
Started to spend some time on the car today, picked up all the loose hardware laying around in the interior, vacuumed all the carpet and the seat. I was very careful not to damage the original plastic still on the carpet. Wiped down the steering wheel, shift **** and e brake handle with some good leather cleaner and conditioner. Looks like they will be in great shape.
Next stop is the engine bay...
Got started on cleaning up the engine bay. This is just to get things cleaned up so I can start working on it, not for show yet. Found 1 dead mouse, 6 cobs of eaten corn, a nice collection of nuts and assorted items and I believe some interior insulation nicely tucked into air cleaner intake!!! Wires all look good thankfully and oil looks clean on the dipstick. Numbers match on the block and I have also added a photo of the race engine and stamping for reference.
Pictures are before and after as well as race engine and stamping.
In a couple of weeks I should have the car on the lift and ready to drain fluids and get ready for a start-up.
Car: 1992 Formula 350
Engine: 5.7 L98
wow.awesome car I thought the GN as the pace car was pretty sweet too. good luck
Very cool!!
Anybody else think the series looks really cool from a fan and marketing perspective but would suck to actually race in? Every time you make contact with anything you have to bring it back to street spec. Having to run crummy brakes that fade dangerously. Real glass breaking. A full interior that could easily catch fire. Soft frame that might not want to bend back. Car's kind of expensive to start with too; I bet you could get a used race prepped 3rd gen for $7k at the time. I guess driving the cars to and from the track wouldn't be that bad but you still need a chase truck anyway. That means two people have to drive at all times rather than one. Hopefully they lived close to Mosport! And then you are driving a car on the street with a cage and no helmet on. Overall I'd consider the series quite dangerous.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The crummy brakes were replaced with larger brakes, and starting in 1988 it became the 1LE package. More or less the 1LE was made for the Players series. The Firehawk series was similar, but it was a little more serious, Firehawk cars could not be driven on the road as I believe they had the VIN removed.
Furthermore the cars had a roll cage to help with structural rigidity.
Right, the cage helped, but I'm talking about the front subframe bending in crashes and also the rear unibody. 1LE brakes certainly helped as well but are good but not great for wheel-to-wheel racing especially on street courses and ovals. Witness drivers blowing corners on the Toronto track due to fade.
I believe many of these players cars were literally driven to and from the track.
As for the front and rear of the cars, the trick to not getting your front end or rear crunched would be not to run into anything. A lot of these cars survived, it is not like NASCAR Sprint cup where every week every car has at least one dent, rub or something that has to be repaired.
Gentleman racing is a bit different than nascar
Now that we are seriously off topic.
It is not just driving around in a circle, it is going really fast to do it, pushing yourself and a machine to its physical limits for several hours is exhilarating.
John
John
And exhausting
The ONLY reason I never became a NASCAR driver was after 50 laps I got board, and lost focus...
Car: 91 Firbird Formula
Engine: 5.0 TBI
I understand racing. I use to race snowmobiles back in the 70's. My point is, with these cars, a road coarse would be much more entertaining. I like right turns as much as left ones.
Supposedly a complete Dual aircleaner setup for one of these on facebook for 75 bux
It's not NASCAR, but ALL spec series have more contact than you see in classes where more changes and different types of cars are allowed. There's no good way to get a run on anybody since everybody has the exact same car. Take a Spec Miata race -- those have a lot of contact. Drivers get frustrated. The cars get bunched up.
Ok, question about the brakes seen in the '86 video. Are they prototypes of the 1LE brakes or did the needs of the teams that season help them determine what the 1LE brakes would be? Are the 1LE brakes better than what they used in '86?
The front brakes i saw at around the 40min mark are 4 piston brembos.
Nice looking dual aircleaner setup for this on FB.
https://m.facebook.com/photo.php?fbi...5892&source=48
#42
IIRC the 1LE brakes are actually from a Caprice? Might be different bolt pattern
John
John
#43
Just the rotor is, kind of, its a 5 on 4 3/4 instead of 5 on 5 bolt pattern but the rotor is from the caprice.
#45
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
One of 26 ! The rarest 3rd gen (by engine) ! Incredible find, and it's in good hands.
#49
#50
Yeah, the spindles are different.
The caparice uses upper and lower control arms but the bearings and seals work.
I think the 1LE rotor uses a bigger outer bearing than the 10.5 rotor.
