UQ7 restoration question
Old Dec 5, 2014 | 08:44 AM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
So, very stupid question. I am restoring my UQ7 package, and i do not know were each wire/connector goes. The previous owner replaced the factory speakers with alpines, and he cut the wires going to each of the speakers. Which wire/connector goes to the sub, and which wire goes to the speaker?
(There is one connector that is held to the wall on each side, if you could refer to that one when you tell me which goes were that would be great.)
Attached Thumbnails UQ7 restoration question-7657th.jpg   UQ7 restoration question-unnamed.jpg
Old Dec 5, 2014 | 06:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: UQ7 restoration question
I wish you asked this a month ago,I had all the panels out,I could have taken some pics for you.
Maybe you could use a tester,turn on the amp switch and see if it lights up,then turn it off to see if it goes out.
Old Dec 5, 2014 | 07:25 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
UQ7 amp wiring.
File Type: pdf
Old Dec 7, 2014 | 11:26 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
for regular speakers it is as follows:
front: lt. green/dk. green; gray/tan
rear left: yellow/brown
rear right: lt. blue/dk. blue
subs are typically red/blk
I did what you did exactly one year ago, except mine was an entire update to the entire cabin wiring.
Because I like whole wires and my car had the switch, but no other uq7 specific stuff, I installed all the wiring by using a 4th gen harness, because it has many wires in it, I sourced similar colors in the lengths i needed and presto, it works. Using the entire radio harnes from a 4th to reapir a 3rd is not recommended as you need to source the terminals and to be really great with wiring. (that is what i did - I enjoy wiring)
Let me know if you need any help, always glad to help especially with cabin wiring upgrades
Old Dec 8, 2014 | 12:57 AM
t/aws61985's Avatar
Engine: Slow ones
Thanks for the help!
92GTA
Apr 9, 2016 07:39 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Street Lethal
Aug 12, 2015 11:33 AM
