RPO replacement stickers
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
Is there a way to get an RPO replacement sticker as long as I have the vin to the car that needs it?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: RPO replacement stickers
Hopefully not. A print shop cannot be held accountable to police this.
The original RPO sticker was a plastic clear coated piece that would be difficult to reproduce. As 1980's cars become more collectible, the market for bogus RPO stickers will emerge. It will happen with Corvettes and turbo Buicks first. When high quality copies become commonplace, I will require multiple original hard copies of proof such as a build sheet, window sticker, and bill of sale before I shell out for a car with 1LE on the RPO sticker.
Engine: 4++,350 & 305 CIs
Transmission: 5-Speed Manual
The above is the sticker Im referring to. I didnt know how much info would be needed to get an accurate account of what this car Ive found has since the sticker is not under the console lid anymore. If I was lucky it would have the build sheet under the carpet as long as its not been removed. Ive only had one 86 t/a that actually had it.
I know which sticker he is wanting. They can reproduce a damaged but readable one.
Can they make one with 0 info about your car? Doubt it.
You may be able to get a list of your rpo codes from GM or pontiac historical services.
All you would need to do is contact GM thru various means with the VIN to verify the RPO codes, no big deal. It's not a 1950s car.
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Just buy a phs document. It will tell you everything about your car. Just as good as a rpo sticker, in my opinion.
PHS does not have every RPO listed and so you can't use that to populate a replacement SPID sticker as the O/P is asking.
Without having a copy of the SPID, buildsheet or a ThirdGen ~1990 or newer, or Canadian ThirdGen, you may not be able to get a complete list of RPO codes as the records are not available for ThirdGen's outside the above noted criteria.
I think that still is the case and has not been shown otherwise. Only ~1990 or newer ThirdGens and Canadian ThirdGens appear to have complete records. Otherwise, you can only get an invoice and that does not contain all RPO codes.
However, an important RPO code like B4U, etc., should be on the invoice anyway.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
hectre13
Dec 11, 2023 08:14 AM
Thornburg
Aug 25, 2015 01:46 AM
