DIY Dash Pad Repair....
Transmission: World Class T-5
Axle/Gears: BW 3.45
I ran across this thread on a different site. I think these materials and techniques would work great on our cracked dash pads, as well as other interior plastics.
http://67-72chevytrucks.com/vboard/s...d.php?t=656250
Axle/Gears: BW 3.45
Re: DIY Dash Pad Repair....
If I ever work up the energy, I may try it on a couple of small cracks on my unobtainium '83 dash pad.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
When spike tv still had Musclecar, they showed a dash pad repair just like this in a 73 buick. I would be curious too see what the repair looks like in person. Another repair I've heard of on a 2nd gen site for minor cracking is to fill with jb weld and push down with another piece of dash to copy the texture.
Charlie I think the only cure for a cracked dash is a replacement. Trust me, I went through this already and I am still looking for a replacement.
Axle/Gears: BW 3.45
Axle/Gears: BW 3.45
It was a 2 part epoxy used to repair plastic bumpers.
I forgot the name of it. Then you have to retexture and paint the pad. I even drilled the ends of the cracks so the cracks would not spread. It was a ton of work and in the end the crack returned. Don't do it. You have been warned.
Axle/Gears: BW 3.45
Okay, I'll just cough up the couple hundred bucks for a new one.
Vintageracer
Sep 24, 2017 12:34 PM
