number of 5 speeds
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
number of 5 speeds
so is there any way to tell how many 5 speeds were made a certain model year vs the automatics? just curious how common 5 speeds were
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: number of 5 speeds
Camaro
83 32111
84 47871
85 27363
86 30371
87 22651
88 19096
89 22923
90 3359
91 15517
92 14211
Firebird
83 13928
84 24378
85 16395
86 16640
87 10557
88 8659
89 8495
90 894
91 2921
92 2770
4 Speeds
Camaro
82 23185
83 3861
84 5232
85 5401
Firebird
82 20964
83 0 (none in my source)
84 1925
85 0 (none in my source)
83 32111
84 47871
85 27363
86 30371
87 22651
88 19096
89 22923
90 3359
91 15517
92 14211
Firebird
83 13928
84 24378
85 16395
86 16640
87 10557
88 8659
89 8495
90 894
91 2921
92 2770
4 Speeds
Camaro
82 23185
83 3861
84 5232
85 5401
Firebird
82 20964
84 1925
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
You sure of those early numbers John? I thought the 5spd was only available with the L69 in 1983. Shouldn't it be 3223 for Camaro & around 700 for birds?
Transmission: World Class T-5
Axle/Gears: BW 3.45
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's the other way around, L69 was only available with 5 speed. As Chazman stated, many other configurations were standard or available with 5 speed.
Car: 86 Trans am
Engine: LG4
So from looking at the numbers it looks safe to assume that only about 1% of the firebirds made in a given model year were 5 speed cars
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
For '85 it works out to about 15%. 180,000 produced, 27,000 with 5-speed. Pretty similar for '91. Probably most years in the 10-15% range. These are numbers for Camaros, I don't have production #s for Firebirds.
Car: 86 Trans am
Engine: LG4
from the tech data on this site there were 110,000 firebirds made in 1986 so that with the 16,000 sticks made that year its still about 10%
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
In what ways are the V8 T-5's and V6 T-5's different?
Car: 86 Trans am
Engine: LG4
i know the bell housings are different, i think something is different with the input shaft as well
Axle/Gears: BW 3.45
To be honest I do not know if the number of teeth were different... all I can tell you is the V8 & the V6 have different RPOs for the Manual transmission... They all have MM5, but the second RPO of MK6, MB1 and M39 were all different internally...
The MM5 is the provisions for the manual 5 speed transmission, more or less it would be the clutch pedal, the shifter, all of the pieces (other than trans). The other RPO MK6, MB1 or M39 was the actual transmission...
Example from 1990-1992
MB1 - V6
M39 - L03 (also LB9 in Convertible)
MK6 - LB9 (coupe only)
MB1 - V6
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
The input shaft spline is different for 6 vs 8 cyl t5s. The six cylinder trans had a 14 tooth input shaft and the 8s had 26 tooth spline. The 6 input shaft is also a small 1 inch diameter while the 8 has a 1 1/8 inch input diameter. Throw in the F*rd T5s and the 10 spline input shaft which is longer than the Chevy and it gets confusing in a hurry.
Car: 86 Trans am
Engine: LG4
MB1 - V6
MB1 - V6
I am not sure about 1986... My guess would be the M39, or the equivalent for 1986...
I know the MX0 (for auto) was the same for the years I am aware of, but the MD8 is the THM700R4 or 4L60, so whether or not they changed the Basic M5 trans for the LG4 to L03 or not...
