Found Build Sheet
Old Jun 3, 2016 | 04:27 PM
KingHD's Avatar
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
Found Build Sheet
After reading some threads about how rare it is to find your build sheet I went and looked under the drivers seat to my surprise I found it. (I looked under the passenger seat to make sure I'm not tripping ***** xD)
Tried to take the seat out to get it so I can laminate it and make a copy but the bolts are sooo rusty that its near impossible.
I'm very happy that I found it and it's for my car
Old Jun 3, 2016 | 09:10 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Re: Found Build Sheet
Good for you King, always great documentation.
Old Jun 4, 2016 | 07:29 AM
Saxondale's Avatar
Car: 84 Z
Work on the bolts. Don't try to remove it with seat in place. Just won't work. Will be worth getting out in one piece, and can fix the bolt situation simultaneously. But of course as you know, if you twist one off you'll need to be ready to fix. May as well have the bolts on hand and drill/tools so don't need to leave home for parts.
Old Jun 4, 2016 | 10:55 AM
KingHD's Avatar
Car: 1987 Camaro
I got the back two bolts out but the two front are so rusty its impossible. Yes I took it out the best I could and taped it up but for some reason its missing some of the bottom. I would've liked it in one piece but by looking at it the paper wasn't in one piece the car has been sat in so many times the paper was used and abused Lol.
Old Jun 4, 2016 | 11:08 AM
KingHD's Avatar
Car: 1987 Camaro
Thanks and once I get this taped up I'm going to the library so I can make a copy and laminate this one.
Old Jun 4, 2016 | 11:46 AM
JT's Avatar
JT
Community Administrator
That's not the master build sheet but instead is a trim sheet. The trim sheets don't tell nearly as much about the car as the master build sheets.
Old Jun 4, 2016 | 11:49 AM
KingHD's Avatar
Car: 1987 Camaro
Do you know if the master build sheet would be in the car?
Old Jun 4, 2016 | 12:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Only the people that used them could tell you if they put it in the car or in the trashcan. Some cars got them, some didn't.
MyNasty91
Exterior Parts for Sale
Apr 7, 2016 12:12 PM
JustinLeonard
Interior Parts Wanted
Apr 1, 2016 09:41 AM
gmancamp
Mar 31, 2016 03:47 PM
soulreaper
Mar 26, 2016 06:36 PM
Roblen91GTA
Mar 26, 2016 05:59 PM
