Caliper paint marks
Caliper paint marks
I generally keep track of this stuff for my own reference, but figured someone else might find it interesting at some point.
I am in the middle of a brake job on my 91 Formula due to a blocked front hose. In this case it froze with the caliper clamped, and smoked the right front brake... Anyway, I noticed a few markings while cleaning up the calipers. I'm reasonably certain the calipers are original equipment.
On the top of the caliper, there's a pink paint dab on the top corner forward of the piston. There's also a white scribble around the opening. On the bottom of the caliper, each has an orange paint dab approximately in-line with the middle of the piston. All of these marks were under layers of brake dust and dirt. They barely show up in photos, but they're definitely there.
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Re: Caliper paint marks
Have to admit, I did not notice marks on the calipers before . . but I did see markings on the rotor hat . . .
I'm guessing the only reason these marks survived to be seen, is that I ran out of brake cleaner and was cleaning the calipers in the sink with warm water, Dawn, and an old toothbrush. The photos I posted were taken shortly after giving the calipers a blast of brake cleaner before a squirt of fresh black paint, the marks were more definitely more visible before the brake cleaner. Had I started with a solvent, they may have rinsed away completely without being seen.
dhirocz
Aftermarket Product Review
Nov 5, 2001 11:54 PM
