RPO CODES
Old Oct 11, 2016 | 12:55 PM
gt4373's Avatar
Transmission: 5-Speed Manual
RPO CODES
Anyone Know Why GM Used 2 Different RPO Codes For The 5-Speed Manual Trans. It's Shown On Both SPID's And Build Sheets.
Old Oct 11, 2016 | 05:43 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: RPO CODES
One was for all of the associated parts and the other was for the actual trans.
MK6 would be the World Class T5
M39 would be the regular T5
Old Oct 13, 2016 | 02:43 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: RPO CODES
MM5 = 5 Speed parts provisions (console parts, etc)
M39 = Transmission Body with 3.08 Final Drive Ratio
MK6 = Transmission Body with 3.42 Final Drive Ratio
Both available with LB9, 5 Liter engine but the MK6 was used in the dual exhaust, higher HP version (230HP with 300 lb-ft torque vs. 205HP with 285 lb-ft torque).
Old Oct 14, 2016 | 08:46 AM
PurelyPMD's Avatar
Engine: LB9
Re: RPO CODES
That transmission decision depended upon the year. My 87 is a G92 car and the MK6 was apparently not available as I got the M39.
SteelheadBen
Nov 27, 2016 12:33 AM
mattbhm
Nov 5, 2016 01:05 AM
2012sergen11
Oct 17, 2016 03:22 PM
HitchDav
Oct 11, 2016 04:36 AM
johng1
Sep 18, 2016 06:07 PM
