Question about my Trans Am
I just recently bought a 1984 Trans Am. It is black and gold and has the 15" gold wheels on it. I recently saw a post on a Facebook page with a pic of a car that was a Recaro Trans Am that looked just like mine. My car is missing the original seats so I was thinking it might be a Recaro Trans Am. The RPO sticker is also missing. How else can I tell what I have. Is there a website that will tell me what I have by using the VIN?
Re: Question about my Trans Am
Y84 is the RPO code for the Recaro Special Edition Trans Am. But the data plate on the radiator support will not list all RPO codes and so it may not list Y84. Look for AQ9 - the Recaro seats.
The SPID sticker in the center console may not have ever been there as I believe that wasn't used until approximately 1985.
The other option is to order a factory invoice. Again, a factory invoice won't list all RPO codes.
This is from the Pontiac Parts book. AQ9 was used between the Lear Siegler and Recaro seats. Even though the data plate doesn't have all RPO codes, many examples I've seen do have that code on the Recaro S/E cars so if that's missing I'm less inclined to believe the car is a Recaro S/E.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I didn't think all early ThirdGens had the RPO sticker in the center console, which is why some need to use the plate.
In fact, Scott Moyer also made such comment:
https://www.thirdgen.org/forums/hist...ml#post5403778
I'm assuming the Firebird was the same as the Camaro in that regard.
84 was the first year for the SPID. The data plate went away in 85 or 86. Seeing as how the data plate is riveted to the car, and usually covers the big options, that's the place I'd look.
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Bingo !!!
Whoever has found RPO SPID's in a 82-83 car, Congrats you have a "frakencar"
Dave
Open your console lid and if you see a white sticker with a VIN # and bunch of codes, Match it to your VIN and if it matches, Then look for a Y84 code and if it's there CONGRATS you have a TRUE 1984 Recaro
If it's NO GO on SPID then
Look at your radiator support driver side is a small plate(credit card size) near driver headlight and it should have Y84 stamped on it
Posting pics or all the codes you see on here will help with your verification of a Recaro edition Trans am
Dave
He noted not having the SPID sticker.
Is Y84 on the cowl tag if it's a Y84? The cowl tag does not list all RPO codes like the SPID. In fact, there was some discussion in the following thread that Y84 is not on all cowl tags for Recaros. That's why AQ9 (seats) is one thing to look for:
https://www.thirdgen.org/forums/hist...82-1983-a.html
This is similar to the 2nd Gens where a few special editions did not have the RPO code on the cowl tag but did on the build sheet.
Dave
Dave
Yes, Correct AQ9 is the RPO for Recaro Seats and should be on the build plate if it's a true Recaro car from the factory
Always have Y84 on my mind for some reason lol
Dave
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
Also, for what its worth, Ive never seen an 84 Recaro with ground effects the same color as the stripes (gold). I believe all cars would have been equipped with W62, but in black. I also think all Recaros in 84 should be L69 (G) cars. If your 84 is indeed a W62 car and by some chance still has the original paint, the GFX should be black. Somebody please correct me if im wrong
