Engine identification help
Old 08-29-2018, 01:35 AM
Imisctoo's Avatar
hello everyone!
I came across this forum and had to sign up after reading a few threads.
I had a 350 book but I can’t find it since I’ve moved. It has all the answers im
looking for. I’m hoping you guys can help me out.
I bought a Chevrolet 350 block tonight. It’s a 2 bolt main. The individual I bought it off of didn’t know much about it.
I got the complete engine for 100.00. It looks like it spun a bearing on the crank. One of the crank bearings was nearly cut in half. I tore it all down and here are the numbers off the block. I’ll add the pictures. Hopefully they work. I basically want to turn this into a 355 to go into a 85 z28.
Is it a good block based off the serial numbers? Should I seek a 4 bolt main instead?
https://imgur.com/gallery/ZXiRRPb
Old 08-29-2018, 01:40 AM
Imisctoo's Avatar
Re: Engine identification help
Here are the numbers to the best of my ability
I see a 638 and then 27 under it. Or it’s 627 under it.
Then I see a G70
I also see H8
27
638
do39 (at least that’s what it looks like)
5.7L6 or lg
GM SGT
14093638
The heads are numbered 18 and 19.
I can hardly read the numbers in them but I think this is what they are
141c2193 I could be way off
the intake has 14102182 and 9028 on it
Old 08-29-2018, 02:42 AM
Drew's Avatar
Received 1,052 Likes on 748 Posts
87-95 350, TBI swirl port heads, with the roller cam provisions but a flat tappet cam it probably came out of a TBI pickup. The block is probably a decent enough place to start. Put a roller cam in it, and all the usual rebuild stuff. The heads are poor, I wouldn't put a penny into having them cleaned, checked for cracks, or rebuilt.
Old 08-29-2018, 11:28 AM
Imisctoo's Avatar
I was wondering if I could put a roller cam in. So I’m good to go on a roller cam?
I’ll put the heads for sale. Which cam do you guys suggest I go with? I want something mild. Nothing too aggressive.
Old 08-29-2018, 11:49 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
comp 285h get some vortec heads from a local rebuilder that have the guides done .
Old 08-29-2018, 02:25 PM
steves's Avatar
Car: 1991 Camaro RS B4C
Engine: 5.7 TPI Crate Motor
Transmission: WC T5
Axle/Gears: 10 Bolt 3.42
I used this website to figure out what motor was in my car. Someone put an L05 in my car. An L05 with TPI/ N10 is all torque.
http://www.1968ss.com/sbcnumbers.asp
Old 08-31-2018, 02:06 PM
Imisctoo's Avatar
Thanks guys!
acliad
05-18-2011 01:58 PM
crazymonkey16
06-28-2010 12:32 AM
sr20fd3st
11-24-2008 12:51 PM
Acidtalons
08-10-2002 06:10 AM
colincamaro
07-31-2001 10:43 PM
Quick Reply: Engine identification help
