Original RPO codes
Old Jan 19, 2019 | 09:46 PM
HeavyOlds's Avatar
Car: 1986 IROC-Z
Engine: 305 LG4 Carbed
Transmission: T5 5-Speed
Axle/Gears: 7.5 10-Bolt 3.42
Original RPO codes
I just recently found out that I could go to my local GM dealer with my VIN and they could print out several sheets of paper listing all my original RPO codes with a description of what they are. The VIN under my console lid didn’t match the car’s VIN so we know someone has changed it. Do you know of anyone that would generate an original looking RPO sticker for a reasonable price? I suppose I could try and make my own with the same font now that I have the info.
Old Jan 20, 2019 | 07:01 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Original RPO codes
Old Feb 5, 2019 | 05:43 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I made mine using an excel file. Came out pretty close to the original label I used *** the template. After I had all the info on it, I printed it on thick stock paper and used packing tape to neatly place it back in the original location. My original became worn and roached after about 10 years of reaching into the console for stuff. This one allowed me to pull off and keep the original and replace it. It has lasted 18 years now and still looks good. If you send your email, I will copy the file and send it to you. You can then alter it for the codes of your car and crate a new label. The file also contains Mfr's ID label and a Tire Inflation label that would go on your door frame. Sorry the picture is pretty fuzzy but you can see the basics.
Old Feb 5, 2019 | 08:25 PM
HeavyOlds's Avatar
Car: 1986 IROC-Z
Great idea. I think that would be really helpful. I sent you a pm. Thanks very much.
Old Feb 6, 2019 | 08:17 AM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Here is a better image of the SPID label I created in excel. If more people would like it, reply or send a PM with your email address.
Tehsocks
Sep 25, 2008 09:05 AM
ebby53
Mar 28, 2002 09:39 PM
Vikingbrew
Feb 7, 2002 12:38 PM
nos
Jan 24, 2002 12:13 AM
