codes, codes, codes
Old Feb 7, 2002 | 12:23 PM
Vikingbrew's Avatar
codes, codes, codes
im flashing 42 and 54.
im thinking 42 is fuel pump relay and 54 is ignition?
there could also be a vacume leak somewhere too...
whats the best way to check for a leak, seeing how it could be anywhere?
Old Feb 7, 2002 | 12:38 PM
89BlueTA's Avatar
Using propane enrichment is the easiest way to locate the vacuum leak. Use a little propane tank, slowly move it around the intake while the car is running. If the idle goes up at a particular spot, then you have found your leak. I think you can use carb cleaner also if you do not have any propane around. Just do not soak the intake, use it sparingly.
nick
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
