Hood latch - painted or unpainted ??
#52
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Hood latch - painted or unpainted ??
John
#55
I had a white 84 Trans Am many years ago with the black stripes around the bottom and I'm almost positive it's windshield cowl was white also. The rest of my early cars I've owned were all black, so that's of no use. I'll have to dig for pics of my white one to see if I can verify it.
#59
Engine: 4++,350 & 305 CIs
#62
So 82-88 most had the black windshield section under the hood, and 89+ none of them did...
Another oddity I have run across is many of the rubber adjustment bumpers were painted at the factory...
John
John
#63
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Was it suggested that Norwood cars had the black cowl? My 87 was a Norwood car and had a black cowl whereas my 88 is a Van Nuys car with body color cowl.
#66
Model year production usually starts around August of the previous year. For example 1990 Camaros and Firebirds, start production around August, and end Dec 31,1989... No 1990's are actually made in 1990. There was actually 13 1991 Camaros, and 13 1991 Firebirds made in Late October of 1989 as pre-production units.
#68
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Dan, while I have you here...
My yellow '85 is a Van Nuys car, but maybe you can shed some light. The inside of the hood and strut towers look like they were repainted after assembly. There are areas where the first coat of yellow is so thin it's see through, barely tinting the primer yellow. Was this common?
#69
Transmission: World Class T-5
Axle/Gears: BW 3.45
All of mine, the 3 I still have and the 3 I have sold, had paint on the adjustment bumpers.
#71
Axle/Gears: G80 GU2
I had a black '86 Camaro that had almost no paint on the underside if the hood. It had basically a pass or two around the perimeter and the center area was just the gray sealer. The hinges also had just a dusting of black paint over the sealer. The fenderwells and such were coated with much more paint. I don't remember where the car was built... Must have been Van Nuys? I'll have to look.
#72
Even after 250k miles the adjustment bumpers on my blk 89 formula have some factory black paint on them.
#73
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Ok I feel stupid. I was looking at pics of my car and thought it had the body color cowl. It is BLACK. Sorry....my bad. Damn reflections were playing tricks on me, I guess..
#74
Car: 87 Trans Am
Engine: 5.0
#76
Engine: that I like
Today I noticed that my silver '85 IROC has a painted hood latch as well. And a black cowl of course. It was built May of '85, at Norwood.
#78
So... We are back to 1982-1988 has a Black painted cowl piece above the firewall and the windshield...
#79
Car: 90 Formula / T-tops
Transmission: MD8
90 has body color cowl and black latch, rubber adjustments body color, more of an over spray
#80
#85
Don't worry, I don't know what or where the cowl is either. I see posts about cowl tags all of the time, but I call that location the radiator support and the other area by the windshield, I've always called the cowl, but cowl tags throw me off. Most of the time, I just say firewall ledge.
#86
Cowl Tags have been misnamed by car enthusiasts for generations. A more accurate description would be a body number plate, or ID plate, not to be confused with a VIN tag. Body number plates were originally on the firewall of the car, you look at the cars from the 60's & 70's you will find that the tags were located on the upper firewall, typically on the drivers side. By definition, the Cowl itself is actually the ledge between the windshield and the Firewall. The plate got this name because it was just under the cowl. In 1982 (according to the Catalog of Firebird ID numbers) tag was moved from the firewall to the front Radiator support on the F-body (which is an odd place because if the car was in a front end collision it could destroy the tag) The tag was actually gone by 1985, as it was replaced with the sticker in the center console.
At any rate the name never changed, People still mistakenly call it the cowl tag, regardless of where it is located.
#87
Car: 87 Trans Am
Engine: 5.0
#88
What about the upper part of the latch and spring mounted on hood? Mine is unpainted and am curious if it should be painted. It's an 87 Norwood built car.
UnionWrkr
Exterior Parts for Sale
11-15-2008 11:25 AM
TommyU
06-25-2008 01:14 PM
jamieriplilb
01-23-2008 08:49 PM
