Differences in L98's from 88 to 89
Old Jul 23, 2020 | 02:44 PM
Abubaca's Avatar
So I owned my 89 for so long that I kinda stopped keeping track of the details. Looking at an 88 now. Just out of curiosity, were there any differences in the L98's from 88 to 90? I know they're both still MAF. Cams??? Tune??? ...anything else? I thought all that info used to be in the tech data, but I didn't see it.
Old Jul 23, 2020 | 04:36 PM
indy82z's Avatar
Re: Differences in L98's from 88 to 89
I know the introduction of dual cats was the big thing in 89. There might be more, but that is what comes to my mind..
Old Jul 23, 2020 | 04:47 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
I'd have to look at the cam chart again, but they should be the same (and best as the 89)
No cold start injector in 1989
1989 got PBR calipers in rear for 4 w disc cars
1989 mid-year got twin cats on performance models
1989 got 3 point rear seat belts.
Old Jul 23, 2020 | 04:51 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
I thought 89s went to speed density. No more MAF
Old Jul 23, 2020 | 04:52 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
I had a couple of 89s years ago and think both were speed density
Old Jul 23, 2020 | 04:54 PM
Big&BadGTA's Avatar
Nope. That was 1990 w/ Speed Density.
Big&BadGTA's Avatar
Old Jul 23, 2020 | 04:56 PM
JT's Avatar
JT
Community Administrator
The upper intake plenum is different from 1988 and 1989 due to the change with how the Idle Speed Control valve diverts air around the throttle body plates. Early style has a separate passage hole in the intake plenum while the later style doesn't.
Old Jul 23, 2020 | 05:52 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Wanna build an L98 when I get a "Round-Toit". Just listening in.
Old Jul 23, 2020 | 06:04 PM
Abubaca's Avatar
Appreciate the input. 89 was definitely still MAF, and... ...same cam apparently. cool!
Old Jul 23, 2020 | 06:20 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The oil pressure sender/switch went to the one device down by the oil filter in 89. The sender was up top next to the distributor in 88 and the switch down by the oil filter.
Old Jul 23, 2020 | 08:49 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I am thinking the long block (with the proper 305 to 350 upgrade parts) https://www.ebay.com/itm/GM-Chevrole...t/253708804971
Or the short block https://www.ebay.com/itm/GM-Chevy-5-...t/262257208884
with a pair of Engine Quest iron heads. https://www.ebay.com/itm/CHEVROLET-3...D/143374526552
Of course, I'd be gambling that the rebuilder, with a so-so reputation, delivers a good product.
For Ca. Smog 89 IROC.
Old Jul 24, 2020 | 12:43 AM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
My bad. I was thinking of not having the cold injector in 89.
Old Jul 24, 2020 | 09:42 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1) 89 First year for the rear seat belt shoulder harness
2) Dual Cats were offered
3) Elimination of 9th injector
4) The Cam, compression ratio remained the same, and were the hottest for the generation
5) Improved programming for the 1989
6) Introduction of VATS
Old Jul 24, 2020 | 10:32 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
My 88 GTA came with VATS
My 89 Formula 350 came with the 9boltt and bigger rear disk brakes
Old Jul 24, 2020 | 12:45 PM
JT's Avatar
JT
Correct. VATS became standard on the GTA during the 1988 model year production:
From GTASourcepage
Old Jul 24, 2020 | 02:22 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Ive also seen 89s with 26 spline rears and 28 spline rears.
Old Jul 25, 2020 | 11:38 AM
Abubaca's Avatar
I appreciate all the replies. ...when the 88 is "officially" mine and in the garage, I'll certainly post up!
mmadden55
Oct 10, 2014 09:45 PM
viperbuster
May 4, 2005 12:35 PM
TJs57TPi
May 2, 2003 08:39 PM
axlenut
Feb 12, 2003 07:52 AM
