88 + 89 IROC-Z with L98, T Tops, and G92?
Hi guys,
Interesting debate came up on a FB group and I can't find much information on it. Could you get a 88-89 IROC-Z, with t tops, L98 and G92? Someone was claiming you could not get a L98 with t tops and G92. Only G80. And I can't find much
Thanks!
Thanks!
Received 1,161 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Re: 88 + 89 IROC-Z with L98, T Tops, and G92?
I believe you could. I may be wrong, though...
i just pulled up 10 88 5.7 irocs with t-tops and they all had no g92 rpo code and all had 2.77 gears .. i pulled up 2 hardtop 88 5.7's and sure enough both had the g92 rpo code and 3.27 gears .. with all the years ive been dealing with irocs i never even thought about this subject .. so it may be true ..
also just looked up a ton of 89 5.7 irocs and no g92 n10 exhaust and t-tops .. looks like g92's were only available in hardtop 5.7's and 5.0 5 speed hardtops .. now pontiacs on the other hand you could
IROCThe5.7L (11-21-2020)
Thanks for the info everyone! Looks like it’s true. All these years and I had no clue.
Awesome, I learned something too!
IROCThe5.7L (11-23-2020)
The variables make it a difficult question to answer. There's almost always a gotcha in there somewhere. That might be a midyear change from GM, or maybe C&C t-tops, or Bubba with a sawzall, which some would consider to be exactly the same thing, but I digress... Perhaps the better question is - "why does it matter?" It's been several decades, T-tops are polarizing, performance isn't limited to what GM built in 1989, so what difference does it really make? The question isn't really as cut and dried as what was available anyway, it's just another thinly veiled question about resale value, or trying to justify preferring or bragging about one car over another.
Community Administrator
I checked Compnine's records for 1989 to see if perhaps there was any indication of the export market different for this case. An example is the 1987 GTA that could get the L98 and CC1 for export only. Compnine shows 253 records for 1989 Z28/CC1/L98 with the Canadian export code. All 253 show the 2.77 gear.
Transmission: World Class T-5
Axle/Gears: BW 3.45
No G92 with t-tops in 1989.
Charlie, I may need to disagree with your last comment. Yes on '87, but I can't find records of a yes for '88. None of the SPID labels and build sheets that I have for 1988, show L98 and G92 on the same sheet. Also, the order guide that I have, modified in December of 1987, states that the CC1 is not available with G92.
Do you have any documentation that mght show the early 1988 cars MIGHT have been available this way? As I said, the order guide, dated 12/87 says it wasn't available.
So, we might have just learned that the only year to get G92, TTops and the 350, was 1987.
Axle/Gears: BW 3.45
ive been looking for the last week and have found none with g92 and t-tops .. ill keep looking
chazman (11-26-2020)
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
For the 1987 & 1988 Convertibles you could get G92 on the LB9/MM5/CC1, but in 1989 you could not, I suspect it was the same for the L98/CC1 for 87 & 88, and then in 89, they no longer offered the L98/CC1/G92/ combination.
This was Camaros only I should mention.
Axle/Gears: BW 3.45
I've seen the verts with the G92 MM5 LB9 but not with the CC1 coupes. Every CC1 coupe with 5 speed in 88 i've seen only had the M39 LB9 3.08 gear. If they did make any LB9 MM5 G92 with ttops in 88 its got to be very limited because i've never came across one in the 15 years i have been searching for these cars. I dont think i've seen any L98 CC1 cars in 88 either.
Also, '87 and '88 LB9 auto could have option G92 in coupe,t-top or 'vert. It included 145 speedo, 3.23 rear and KC4 oil cooler.
BizJetTech (12-01-2020)
Someone please correct me if I'm wrong but I thought for 1987 L98 IROC's there was no G92 option, just the 3.27 geared 9bolt.
From 1988-1989 with the L98 with 2.77 gears were standard and the 3.27 gears became the G92 option.
Axle/Gears: BW 3.45
My 88 IROC-Z convertible that I just sold had no CC1 on the SPID. 6th digit of the VIN is a 3 for factory convertible, G92, LB9, G80, MM5, KC4, GM3, J65, all the goodies
Axle/Gears: BW 3.45
I shouldn't have called it CC1, I should have just said t-top. They were built as t-tops, minus the tops and rear hatch and shipped to ASC. I think there was a picture on TGO a few years ago, where they had plugs covering the openings on the transport truck. Anyone have that pic handy?
That makes sense I had heard they were all t-top cars before, and just assumed they'd have CC1 on the SPID
How many were made??? IDK...
Axle/Gears: BW 3.45
It seems that the literature is unclear about the combo of t-tops, G92 and L98 in 1988. I could swear it was available, but I honestly can't remember the last one I've seen. We need to produce an example of a car so equipped to put this to rest.
IROCThe5.7L (12-03-2020)
im still looking and came up with nothing .. a 88 popped up near me on marketplace and its a hardtop l98 and wouldnt you know it , it has g92 3.27 gears .. almost ever hardtop seems to have it that i have found ..
chazman (12-02-2020)
Come to think of it I haven't seen an 88-89 iroc with the L98 and t-tops with the G92 option. Not to say they arent out there, I just haven't run across one. Most were like my 88 t-top L98 and came with 2.77's. I changed my gears to 3.45s and it really woke the car up in terms of acceleration. Wish they all came with G92 and posi as standard.
Im starting to think it was only an 87 combination on the iroc. Pontiac is a different story though. Ive seen some different sides on the order option sheet between the birds and camaros but 88-89 G92 camaros i've seen so far are all hardtops.
Based on this new discovery, I'm changing my asking price on a 1 year only performance package w/ TTops, 1987 IROC-Z. The 1st $100k takes it!!!
Che70velle (12-13-2020)
https://www.lafontaineclassiccars.co...ro-iroc-z28-2/
This one is more than likely a 2.77 gear car but the dealer says it's a posi 3.42 which i can assume was swapped at some point because G92 auto in 88 was 3.27s. Idk if the swap is true or the dealer doesn't know what there talking about. This car maybe worth investigating. It had a pic of the rpo codes but its not clear in the pic.
My 1989, T-top, 5.7 car also has 2.77's
Hi all, I got my first ever Camaro 3rd gen today.
Bought from 1st owner ,the gentleman had it since 1988 when he bought the Camaro in Arizona.
It has 5,7 tpi engine ,T tops & the G92 option....I read here its pretty rare but mine has it.(also has 4 discbrakes)
car is now in Europe ,shes a 1988 model in white ,Iroc Z and off course auto gearbox in combination with the 5.7 tpi engine..
I sold my C 5 corvette and now have this beautiful Camaro 1988 ,which btw makes a beautiful sound...
The 1st owner bought this car as a showroom model that was displayed ,so might be well equiped....
Hope this helps ,best regards all...
The following 2 users liked this post by dagwood:
BizJetTech (09-07-2022), Petrov (09-07-2022)
Hi all ,I am a novice,any important things ,pls let me know....Its a 5.7 T-top with G92 option 1988 model ,now wondering if its special or rare...many thanks all...
Thank you for the SPID picture. It's weird that it's printed with the body color at the top, and the RPO's at the bottom. Never seen a SPID like that before. Anyways, I was looking to see if your car actually came with those options from the factory, as they never made any G92 cars in 1988 with t-tops. Your SPID confirms that your car has had aftermarket t-tops installed. The factory RPO code for t-tops is CC1, which your car does not have. I'm not saying that's bad by any means, but that was the only way in 1988 that you were going to get the good rear end gears with t-tops.
It is also showing a black car with silver on the bottom. Can you post a pic of the car??
The following 3 users liked this post by dagwood:
Ok ,well thats abit weird ...
The car is white ......
ill post a pic ,thought it was an all original car as the guy I bought it from bought it new in Phoenix and chevs&vettes or something like that...
Going to check the history folder and invoices...
#42
The RPO code for factory T-tops is CC1. This RPO code is missing from your SPID label. You car most likely has Cars & Concepts aftermarket T-tops installed.
I swear when I started this reply His SPID label post was the last one. LOL
Like Dagwood said about the SPID label, Its formatting is odd. Also first I seen with the paint codes at the top with RPO codes below them.
Petrov (09-07-2022)
okfoz (09-07-2022)
Petrov (09-07-2022)
#45
Those are DEFINITELY C&C t-tops. I have them in my race car. You can see the difference right away by the bigger gap between the front of the t-tops and the windshield. They also have the trim on the roof of the car along the back edge of the glass, as well as the front edge
BEAUTIFUL CAR!!!
BEAUTIFUL CAR!!!
#47
Car: '89 GTA
Engine: ZZ6TPI
Those are aftermarket Cars and Concepts T-Tops. Nice car.
#48
Thanks all ,ok so that mystery is solved .
As a novice I didnt know they did aftermarket t tops....
Was hoping for the car to be all original.
The colour is white and sticker says black.....cant understand that but must have been repainted as I dont think they mad emistakes on these code stickers.
Car is beautiful and have full stack of service history.
Its in Europe and the prices are going up for these cars ... I hope I made the right choice to buy this one ,she drives great though...
Very grateful ,for all the info...
#49
Also check to see that your VIN matches the one on the decal, but i would almost bet the format got off on the printer
Petrov (09-07-2022)
#50
Oh, and since you're new, WELCOME to TGO!
