Question about a build sheet found in the car
Old Apr 16, 2025 | 07:22 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
I was taking the door panel off in my 92 Camaro RS to replace weather stripping and I found what I thing is a build order or options sheet. Top right corner has "Schedule/Job" with a number. Is this something else than the options sticker found in the trunk area?
Old Apr 16, 2025 | 10:44 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Question about a build sheet found in the car
Not sure what the formal name for that paper is. It's not the build sheet, but it obviously references some of the build features. Mine is under the carpet in the rear cargo well, but it's partially glued to the sheet metal by the factory's dollop of adhesive that was placed to hold down the carpet. It looks good, but at nearly 40 years old, it's probably too fragile to try to remove, so I decided to leave it there. Trying to remove it would probably be like unwrapping a mummy, and it would crumble if disturbed.
Old Apr 17, 2025 | 08:50 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That is a build sheet, but not "The Build Sheet" If that makes sense. Normally they are partial, and not complete for the entire car. They are still a great find.
Old Apr 17, 2025 | 10:25 AM
VIZ28's Avatar
Car: 1989 RU7 1LE / 1997 RS
Engine: 305 TPI / 3800 Series III
Transmission: T5 / T5
Axle/Gears: 3.45 / 3.23
It's really cool when you find one that says RACE or RACE CAR on them!
Old Apr 17, 2025 | 11:30 AM
JT's Avatar
JT
Community Administrator
I don't refer to as the build sheet, since it's not "the build sheet" as John notes, but a trim sheet.
The number on the sheet should match the number on the metal plate in front of the radiator. It would also be on the master build sheet. It's not on the SPID label.
Old Apr 17, 2025 | 02:41 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
And verify the numbers match. It was common to find build sheets under the seats/carpet on 2nd Gen F-body cars, but also not rare to discover one of the guys on the line just dropped the sheet he had in his hand from another car into the car you now have. I guess his pockets finally got full of wadded up paper! VINs on the build sheets verified that then.
Old Jun 14, 2025 | 12:05 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
My build sheet is 1/3rd behind the evaporator core opening on my GTA. I noticed it when I took off the evaporator core box assembly from the engine compartment. I still haven’t removed it yet in fear of ripping it in half. I guess I’ll have to take apart the dash to get at it from the inside. Ugh!
Old Jun 16, 2025 | 03:39 PM
okfoz's Avatar
A lot of the time the build sheets behind the dash are partials, they typically only deal with the parts that were to be included with the dash. BUT they are still a cool find, and there is a possibility that it is the full Build-sheet.
Old Jun 16, 2025 | 09:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Trim sheet, a mini build sheet if you will,
there are several of those in different areas.
Old Jun 16, 2025 | 10:28 PM
JT's Avatar
JT
That's what I call it, a trim sheet, but mini build sheet is too generous. The trims sheet contains so much less than the master build sheet. Doesn't have all the RPO codes, only a few, no dealership selling information.
RedLeader289
Feb 11, 2023 02:26 PM
meangreen92
Jan 29, 2012 10:01 AM
Big Dave
Feb 12, 2008 12:24 AM
The_Prostitute
Apr 18, 2003 08:35 PM
TorchRay
Feb 18, 2003 12:39 PM
