How to get a list of RPO codes for my car
Old Oct 1, 2025 | 11:29 AM
thefirebirdm@n's Avatar
Car: 1989 Pontiac Trans Am GTA
Although my 1989 GTA is very original, I am 3rd owner, it seems like the decals containing all the RPO codes are missing. How would I go about getting all the RPO codes for this car? Is that something PHS can help with?
Old Feb 10, 2026 | 08:55 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: How to get a list of RPO codes for my car
PHS only goes up to 1986, they used to do newer, but GM wanted to take it over so they forced their hand.
You can get your Dealer Invoice through https://www.gm.com/heritage/archive, it will give you your options, the price etc.
It used to be free, but it was $50 the last time I looked.
Old Feb 12, 2026 | 06:21 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
As John stated, PHS was muscled out of the post-1987 documentation business by GM. The info you get from GM Heritage will only show what your invoice showed: as far as UPC codes go, the only thing you'll see will be the UPC codes for the optional equipment.
Your best bet is probably finding someone who has a car equipped the same as or similar to yours and "build" a UPC code list that way. Shouldn't be that hard to do, really. I can try to help you if you like.
Old Feb 13, 2026 | 09:26 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
https://www.compnine.com/vid.php
This is your best bet. They have an archive based on the VIN.
Old Feb 13, 2026 | 10:14 AM
JT's Avatar
JT
Community Administrator
The problem in this case is the OP has a 1989. Compnine only has a small fraction of 1989s in their database so it's most likely not there, especially if it's not an exported one. Their coverage increases for the 1990 and newer years.
Dead Reckon
Mar 4, 2012 10:30 AM
SC82TA
May 13, 2003 10:40 PM
86LB9
Oct 9, 2002 05:00 PM
CaysE
Oct 8, 2002 09:25 PM
