[AR] Custom Car Audio Door Speaker pods
Car: 1971 Camaro
I built these for my TA but decided to leave my doors smooth for now. There are fiberglasses and wrapped in white vinyl.
The reason I did white vinyl is so they can be colored to match any interior using sem color coat.
Dimensions are 3" deep at the highest spot and what's listed on this picture.
It fit my Firebird pretty good, it's a little tight in this area here but still should work, worst case scenario you might need to grind a little out fo the armrest in that area....no big deal since armrests are dime a dozen...if you are using the old style armrest I'll supply a set modified at no additional cost.
They will hold two 6.5" speakers flush or smaller if you make some adapter plates out of 1/4 mdf. The cut out specs are 5-5/8" for the actual speaker cut out for the basket and 6-3/4" so the speaker will sit flush.
I was going to use kicker mid-bass speakers (not included)
Get the only set like these before it hits eBay.....
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Custom Car Audio Door Speaker pods
I live in Malvern AR, where are you located and I may come take a look?
Car: 1971 Camaro
Since nobody seemed interested they are now listed on eBay starting out at $75.00 as a "universal" set since they will fit flat door panels.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
kah992
08-19-2015 02:55 PM
db057
08-11-2015 10:11 PM
