v6-v8 tachometer
Old Oct 23, 2006 | 04:05 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
v6-v8 tachometer
i currently have a v6 tach in my car.... i will be dropping a 350 tpi in the car within a couple weeks... the post of v6-v8 swaps says i will need a tach from a v8... anyone know if this is for sure? and if so have one in good shape
Old Oct 25, 2006 | 09:26 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
had both in my car no visible difference both worked fine
Old Oct 26, 2006 | 11:33 PM
Firebat's Avatar
edit: nevermind, I only have firebird tachs, won't work for you
Old Nov 4, 2006 | 07:22 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You don't necessarily need a whole new tach (or cluster), you might just end up buying a piece of junk.
Instead, you can recalibrate your tachometer to show the right numbers for an 8-cylinder engine. Won't cost you more than maybe a $1 for resistors.
Do a search and you'll find a big thread about this.
Hope this helps.
Lou
Old Nov 6, 2006 | 09:48 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
They are different. I swapped a 145mph cluster into my car and the tach was off. The tach itself was the same, but the chip underneath it is different, so I just popped out the chip from my 110 cluster and put it in and it all worked fine. If you can't find a good deal on a 145mph cluster like I did (or just don't want the 145mph cluster) just look on eBay or wherever for a cluster out of a V8 car. The 110 clusters are dirt cheap.
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
99Hawk120
Mar 13, 2002 02:24 PM
