"I need 145-160MPH Speedo for a 1982 T/A 305CI H.O".
Old Apr 6, 2008 | 04:05 AM
82Knight's Avatar
I need a 145MPH to 165MPH Speedometer or a Speedometer that goes over 85MPH.
The car I will be putting it in is a black 1982 Firebird Trans Am, 305CI H.O.
and im looking for one that is cheap nothing over $100.00 please.
- Thanks Nic -
Old Apr 6, 2008 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: "I need 145-160MPH Speedo for a 1982 T/A 305CI H.O".
Did GM ever make a mechanical speedo for a TA that went over 85?
JamesC
Old Apr 7, 2008 | 05:56 AM
82Knight's Avatar
From what I understand they do but they are way overpriced....
Old Apr 7, 2008 | 06:07 AM
JamesC's Avatar
You might double check your info. The 145's, for example, didn't appear in Camaros until 86, IIRC.
JamesC
Old Apr 7, 2008 | 07:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Years ago; I saw a cable driven Firebird speedo that read 160MPH or something like that. The guy told me it was a GM part - but not factory installed. Kind of like the 145 "Z28" speedo for the 82-84 Camaro.
I've got a 84 TA cluster showing 140,............... But it's METRIC and the readout is in KPH !! ( from a canadian car ).
Sorry I don't have what you need - just adding my !
Old Apr 7, 2008 | 09:35 PM
rhead007's Avatar
Car: 73LT,81Z,85Z
Engine: 350 350 350
Transmission: 700r4 700r4 700r4
i got a 140 set up from an 89
Old Apr 7, 2008 | 11:20 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Factory 140 MPH Speedometer GM Part Number 25053568
Corvette Clinic 160 MPH Speedometer
Old Apr 15, 2008 | 11:08 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
do a search on ebay a speedo company makes em less then a hundo, also heard camaro units were mechanical until late 80's and bolt right in may need a needle change
Old Apr 16, 2008 | 05:10 AM
JamesC's Avatar
Just an FYI: Camaro speedos were mechanical from 82-89. The speedo head is a direct swap. No need to touch the needle.
JamesC
Old Apr 23, 2008 | 09:44 PM
jwdomino's Avatar
Car: 82 Trans Am
Transmission: t-56
JamesC
not true, some speedos had white needles some orange.... thus a change to match yours may be necessary
Old Apr 24, 2008 | 05:32 AM
JamesC's Avatar
I see. While that may be true, messing with the needles is a design for disaster: plastic, fragile, breakable. And, of course, even if you're successful, you'll have to fiddle with the needle again to get the head to read correctly. Possible to do, yes; recommended, no. If you swap in the entire cluster, there'd be no need anyway.
JamesC
Old Apr 25, 2008 | 07:19 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
I have an extra 145 mph gage cluster laying around it's in good shape just collecting dust in the garage
Old Apr 26, 2008 | 09:49 PM
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
Simo, do you think that speedo is a direct fit for an 85 TA with TPI?
Old Apr 26, 2008 | 10:15 PM
simo's Avatar
Engine: CFI - 305
It would be a direct fit for either of them but the 85 gauges have the crossing pattern on the gauge faces rather then the plain black surface. You can contact http://www.autoinstruments.com
They have this for the 1983.
They may be able to do a 1985 as well.
There is also http://www.speedometerplus.com/
Good luck.
Old Aug 5, 2008 | 04:53 AM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Where would I get a metric speedo for my 88 GTA? Our speed limits are all in KPH here.
2012sergen11
Oct 13, 2015 07:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
rusty vango
Sep 29, 2015 02:44 PM
indygene
Sep 26, 2015 11:21 AM
