[PA] REAR set of RED seat belts...
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
i need a set of rear seatbelts that are red.. male and female ends..
also it needs to have the little braket that bolt to the seat itself..
let me know.. need for inspection...
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: REAR set of RED seat belts...
If they will pass you with rear lap belts i can get you a set. I know they aren't 3-point belts but they are a seat belt none the less. Let me know if you think they will work.
Jon
Jon
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a set,...... $45 Shipped. One side is missing a little piece of red plastic trim on the latch. Both in good working shape, from a 91 RS.
If your interested just send me a PM and I'll respond with the details !
im in Schnecksville, pa
where are you?
where are you?
well 2 hr drive for seat belts not really worth it.. ill do the 40 bucks shipeed.. can u get me pics to lopezisgod@gmail.com first
thx
thx
retractors work correct?
ok then.. pm you info for paypal..
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
