85+ AC Delete Firebird Dash
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I'm looking for an AC delete dash and controls for an 85+ firebird. I'd really like to buy the whole dash board, cluster and all. But mostly looking for the heater controls, cables for the controls, and the dash itself.
Alex
Alex
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: 85+ AC Delete Firebird Dash
I have the dash, gauges (gas and speed), most of the harness ( i think i cut it by the firewall), and i might have the non-a/c controls, but i may have sold them. So if someone else has the cables and controls, i have the dash board and basic gauge cluster.
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i can help with some of the parts,,
i have the wiring harness, inside heat box, inside duct work, might even have the block off plates for the dashboard not sure will need to check on those , heater control head, both left and right fresh air boxes, cables and plate. just missing firewall blower motor box,
I'm not sure exactly what I need and what can be used from my AC dash.
84redta: How much do you want for the dash and cluster? And could I get a pic of it?
ted: How much for the controls, air boxes, cables, heat box, duct work and plate. Also, could I get a pic of the controls?
BTW does anyone know if I would need the wiring harness.
Alex
Alex
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If you don't work out a deal with these guys than send me a PM. I've got everything needed for a Firebird conversion.
Non-AC Air box
Block off plates
Heater (core ) box (cable type)
Center Console Controls (Firebird)
Fresh Air boxes
Under column trim with vent controls
Engine Firewall non-AC Blower box
Non-AC harness
I've got a couple clusters too.
Transmission: auto
whats your e-mail addres for all of the pics, and yes its a plug in harness and i have that also
Thanks guys, you can email me at bendixaviation@yahoo.com
I've only got a $100 at the moment and I'm on a tight budget so if I didn't have to buy a complete dash that would be awesome.
Thanks for the help guys.
Alex
Alex
ambainb
Apr 25, 2016 09:21 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
