1982 Trans Am/Firebird auto shifter knob
Old Apr 1, 2010 | 02:55 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
1982 Trans Am/Firebird auto shifter ****
Hey guys, I'm looking for an auto transmission shifter **** out of a 1982 Trans Am/Firebird. I'm looking for just the ****, the round one before they switched to the t-handle type in later years. Thanks!
Old Apr 1, 2010 | 04:35 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 1982 Trans Am/Firebird auto shifter ****
You do know that your gonna have to change the whole shifter assembly to make that **** work on a 1991
Old Apr 1, 2010 | 07:04 PM
Engine: LB9
Really? I've seen a guy with an 86 do it. Oh well, I might fabricate something. Would the **** work with a shifter from an 83-newer car in case the 82 is hard to find?
Old Apr 2, 2010 | 07:57 AM
my82roc's Avatar
Its the way the **** mounts on the shift lever thats different.The **** has 2 metal tabs inside the sleeve that fit into slots on the top of the shift lever and is then secured by a small metal c clip that snaps over top.You can use a camaro shifter assembly from 84-86 as they came with a round ball shift **** that mounted the same way and also has OD on it.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
