Power Lumbar Harness and Connector
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
I am looking for the driver side seat connector and power/air line harness (to the passenger seat). The seats were from a 95 Trans Am, but the connector is cut off the driver seat (passenger seat is fine). I am installing into an 85. Thanks for your help.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Power Lumbar Harness and Connector
I can't be sure this is the right one for you - so look at the connectors in the picture close to be sure. I got it with a set of fourth gen seats and never used it. There is a 4-wire connector and an air tube at for each seat as well power and conenections.
$20 + shipping. Send me a PM if your interested.
[quote=John in RI;5070639]I can't be sure this is the right one for you - so look at the connectors in the picture close to be sure. I got it with a set of fourth gen seats and never used it. There is a 4-wire connector and an air tube at for each seat as well power and conenections.
Hi, thanks for the reply. The harness from the Trans Am seats seem to be a little different. It is a 5 wire system plus the air line.
I am sorry too! Greatly appreciate the reply. Hopefully someone on here has one.
