looking for a complete hatch pull down motor
Car: 1989 formula firebird
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
It must be a complete working unit with relay, latch ..ect. Just purchased a new motor for my car but can't get it to work right it only works if I ground it at the motor switch. If you have any ideas let me know also
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: looking for a complete hatch pull down motor
Check eBay, I see them for sale there a lot. Most of them are used and even if they are working, I'd buy a new main plastic gear and replace it in any used unit before installing it just to be safe.
Car: 1991 Camaro Z28
Did you check the little plastic flipper underneath the latch that engages the motor to pull down? Just did this last week and thought I was going to replace everything, but it was just the little flipper.
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
are you talking about the up and down stop switch attached to the top of the motor or the striker switch? I can get it to work if I ground the motor direct one way or the other. Also my relay makes no noise either is that strange?
I'm talking about the small plastic flipper right by the latch that catches the trunk as it comes down. If you push it down, you will engage the motor and it will pull down. As to the relay making no noise.... Don't think that's a good thing
Engine: 305 tpi
Transmission: m5
Axle/Gears: 3.45
purchased one from tony v but thanks anyway!
Terrell351
Jun 13, 2021 01:13 PM
