looking for 90-92 z28 dash harness
Old Jan 2, 2014 | 08:18 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
hi I am trying to get my car back together and am finding more problems than worth fixing in the dash harness.would pefer a manual trans with full power and power seat if possible
thanks
Old Jan 3, 2014 | 07:58 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: looking for 90-92 z28 dash harness
I've got a dash harness from a 90-92 TBI Stick,... $95 + shipping.
The harness was from a 92 (maybe 91) RS 305 TBI RS. The rear defroster wire is GOOD, the radio plugs are ORIGINAL, no hacked plugs. I found 1 spliced wire on the whole harness ( the wire runs from the tail light harness plug - see top of picture.) There are no relays/stuff attached to it like VATS, SIR, ect......
Old Jan 4, 2014 | 11:45 AM
driver101's Avatar
that should work did the car have power windows and locks?
Old Jan 4, 2014 | 12:57 PM
John in RI's Avatar
All 90-92 dash harnesses are wired for power lock/power windows. To add Power lock/windows you stick a couple circuit breakers in the fusebox and install those optional parts and wiring.
Do you currently have power windows ?
I found another splice in the harness near the fusebox just now when inspecting it. At I've been without my camera for a few days and trying HARD to get it back; As soon as I can post a pic - I will. (splice should not be a problem )
There was no Cruise Control, VSS, VATS modules, and the starter enable relay is gone. The factory radio wiring was original, I saw the rear defroster connector, and the rest of the dash harness looked fine. I might still have a relay or 2 so If you need them, I'll check.
What's your ZIP code ??
Old Jan 4, 2014 | 01:42 PM
driver101's Avatar
yeah the car is full load i was trying to find a complete harness as i hacked the old one up and the new one has several problems one of them being the acc fuse blows,vats issue,and tach issue so i really don't want to use any of it if i don't have to. my zip code is 77049
Jorlain
Aug 24, 2022 05:11 PM
toones
Jan 6, 2016 06:00 PM
stalkier
Dec 6, 2015 11:25 PM
IBrockZ
Aug 20, 2015 12:20 PM
355tpipickup
Aug 19, 2015 10:02 PM
