[NY] 85 Dash Pad
Car: 85 Camaro Berlinetta
85 Dash Pad
I traded off my 94 v6 for an 85 berlinetta and it needs some parts. I would really like to find a non cracked black dash pad for my car. The pod radio also if someone has a good one cheap. Let me know if you have one and what you want for it.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 85 Dash Pad
I've got a non-cracked dash pad as well as a working non-cassette Berlinetta Deck. They are both in good shape,......... these are not "cheap" parts your asking for. If your truly interested than feel free to shop around & then make a serious offer for them. Be sure to post your ZIP code for a shipping quote.
Re: 85 Dash Pad
Dash i know isnt cheap but the radio pod should be since it tends to not work alot of times. Mine only lets the dash speakers work sometimes or just 1 if it doesnt glitch out and just make loud noise when its off.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: 85 Dash Pad
Sounds like the radio module could be bad, not the radio if all the buttons and such work correctly.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: 85 Dash Pad
If you know how to solder you might be able to fix some of the issues by re-flowing the solder. Could also try replacing old capacitors.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: 85 Dash Pad
I've got a cassette radio and control module for $115 shipped in the lower 48. I know the radio itself and all the functions work. I do not have any cassettes to test that part, the door opens and closes good.
Engine: V6, V8
Re: 85 Dash Pad
Remove the plastic console cover, disconnect the wiring connector and unbolt the base. There's a spring/clip underneath that you need to keep an eye on. It's there to allow the upper portion to be set at certain angles. The back of the upper portion has very small screws.
The bottom should simply unbolt, and iirc contains the speaker outputs which may be where the problem is. You would want to carefully open the case while remembering how it goes back together.
Then look at the solder joints to see if they're shiny or greyish. If they're greyish (oxidized), then you would want to reheat the joints with some electronics flux to re-flow the solder.
Found a vid with a quick search: http://www.youtube.com/watch?feature...YA9ufb4Jc#t=17
(Actually not the best solder job, but shows the principle of it. It's common to add solder but you really only need to add flux.)
It's been a few years since I've opened one so the above may not be entirely accurate. If some of that is above your head try asking an electronics friend if they might be interested in doing it.
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: 85 Dash Pad
i also have a non cracked dash pad been in storage for years no need for it anymore asking $200
Re: 85 Dash Pad
I'm betting that the speaker problems your describing are caused by the reciever that gets mounted inside the center console. It COULD be the radio "head" - but the receiver is usually the cause of Fade/Balance problems.
Be advised,.... the radio receiver for a non-EQ radio and the EQ style Berlinetta radios are NOT the same.
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Vintageracer
Sep 24, 2017 12:34 PM
