Need hatch pull down motor 89 IROC
Old Sep 9, 2014 | 11:31 AM
Viking's Avatar
Car: / 89 IROC /
If anyone has a working one for sale please message me
Old Sep 13, 2014 | 10:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Need hatch pull down motor 89 IROC
I've got a good one,..... send me a PM for details if your still looking for a good replacement.
Old Sep 17, 2014 | 10:26 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Sent Pm
Old Sep 19, 2014 | 12:13 AM
wwe442's Avatar
Car: Too many!
I have a few. Car looks pretty good for 300k! I have an 88 Silverado with 419k but she isn't as pretty
Old Sep 26, 2014 | 04:58 AM
Johngypsy's Avatar
Car: 1990 Iroc z
Engine: 5.7 liter Tune port 383 stroker
Transmission: 5-speed
Axle/Gears: 3.45
John Iroc z parts and supplies
110 dollars
actual General Motors with under 67k org miles
Garaged kept car, so the rear hatch motor is nice and texted good,
From a 89 Iroc and also a 90 Gta car
Also 110
Johnjohninht@gmail.com
Old Oct 21, 2014 | 02:21 PM
Viking's Avatar
Car: / 89 IROC /
Hi guys, thanks for the offers for the hatch motor. I did get a new one locally, but that's not working either, so I am going to make sure I do not have an electrical issue first before I buy another. Will let you know if I need one, thanks to all who replied.
Old Oct 21, 2014 | 02:47 PM
Johngypsy's Avatar
Car: 1990 Iroc z
Axle/Gears: 3.45
Take off the center Counsole, there is only 1 red plug wire that goes I to the rear of the un-lock power, just take a simple light tester and test the wire, but be careful, u will only get power when the button is pressed down some are just stright power, but just hold the button and check for the light to see if power is going threw it, if power is good? Check the rear hatch where the ground is located at, if all is good? Then just jump the rear hatch motor manually, vey simple, but u must again have ground to do so, if all els is good? Get your money back as most of them ordered new is and are duds, happened to tons of guys on here, I myself is one of them,
If by chance u have another Camaro or firebird or a friends ask if u can just use there truck to test out your motor, maybe just 1 wire out of the 5 are not connected somewhere, but remember u have 2 grounds, not 1, good luck and post back with your findings,
John
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
1nastygta
Aug 8, 2015 07:38 PM
