[AR] 1988 Firebird Underdash Panel -Drivers Side
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Looking for a complete LH drivers side underdash trim/hush panel for an '88 Firebird . Do not need the light, fuse box door or even the foam insulation...have all that already. Need all mounting slots to be solid, no cracks. Thanks.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1988 Firebird Underdash Panel -Drivers Side
Auto or Stick ?? If you send me your ZIP code I'll take a couple pics and will reply with the pictures and shipping quote.
Axle/Gears: 3.45, 3.27, 3.27
I'm confused. Why would it matter if his car is an auto or stick? I am not aware that there is a difference on this under dash panel (aka hush panel).
Lon
Lon
On the drivers side panel there is a 'cut-out' for the clutch pedal on stick cars.
Someone could just cut the auto version of the hush panel so there is a slot for the clutch pedal; but there are 2 factory versions of the hush panel for the Camaro and Firebirds with AC, and 2 more versions of the hush panel for cars without AC. ( at least for most years, not sure about 90-92 )
Engine: 5.7L TPI
Axle/Gears: 3.27:1
John, the car is an '88 GTA, 5.7L auto. Zip code is 72501. Thanks.
I've got a family function today so I'll write back later tonight with an update including pics and a shipping quote for Ya' !
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
I have one in good shape. 30 shipped pm me if you still need
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
