Seatbelt Recall
Old Mar 17, 2010 | 09:37 PM
  #401
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Seatbelt Recall
Originally Posted by z28_87Camaro
Thanks Dan,
I'll give Collin a shout tomorrow.
Hopefully he has better luck than the guys here.
Can Collin check my vin # to see if my 86 IROC is covered? If so, I want to throw it in the face of my local GM Dealer Collin pulls up that my Camaro is valid for the recall.
Old Mar 18, 2010 | 01:07 AM
  #402
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Seatbelt Recall
Thanks Dan,
Hello z28_87Camaro!!
Mertin's GM in Chilliwack, phone # 1-604-795-9104 ask for Collin in parts!! I called him today about 5 o'clock, and gave him a "heads up" for you!!
He told me that the parts are still showing as "available" from the States!!
Just to be on the safe side, I ordered two sets, @ approx $10.50 each!!
Old Mar 18, 2010 | 01:19 AM
  #403
Re: Seatbelt Recall
Hello Chevy86 IROC-Z!!
Call Mertin's GM in Chilliwack, BC at 1-604-795-9104 ask for Collin, give him your VIN#, it might just work for you!!
I was informed by GM Canada about my 1987 IROC-Z being under a recall, for the seat belt buttons, when the recall came out, IIRC, early 1990's!!
For my 1987 Z-28, which was bought private sale in November 2009, I took it to the dealer for a fuel pump replacement, and they ran the VIN# to see if any recalls came up, and the seat belt button one came up!! So they ordered the parts, and after a bit of a mechanic's "problem", I ended up fixing the buttons myself!!
Old Mar 18, 2010 | 01:25 AM
  #404
Re: Seatbelt Recall
Good deal. Thanks Dan. I'll give Collin a ring tomorrow. Agian, thanks.
Old Mar 18, 2010 | 01:36 AM
  #405
Re: Seatbelt Recall
Hello Chevy86 IROC-Z!!!
Good luck!!
Old Mar 18, 2010 | 09:19 AM
  #406
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Seatbelt Recall
THe parts are cheap, I found the sets of buttons and replacement parts for a few bucks... it was about the same price as shipping...
The tools are the thing that are impossible to get... ModernMuscle I think has some alternate tools for fixing the latches... I have not tried their tool yet, but I have it...
John
Old Mar 18, 2010 | 11:09 PM
  #407
Re: Seatbelt Recall
John
Hello okfoz!!
You really don't need any tools except a "small" screwdriver, as long as you are careful, you can accomplish this easy job with a little TLC, and a "small" screwdriver!!
I used a 1/8 inch wide flat tip, three inch long screwdriver. I put the blade into the button at the corners, and using the slightest upwards pressure, while using my index finger as a fulcrum, I popped the button off!!!
Three done in 15 minutes, the other one was a bit longer, as I had to go to the junk yard for a replacement button holder, that the "nice" Goodwrench part changer broke, using a "BIG" (foot long, 1/2 inch wide flat tip) screwdriver!!!
I even managed to remove the broken button holder with two "small" (1/8 inch wide flat tip, three inch long) screwdrivers!!!
TLC, I can't say it enough!!!
Old Mar 19, 2010 | 12:46 AM
  #408
Re: Seatbelt Recall
Any luck with Collin???
Old Mar 19, 2010 | 05:42 PM
  #409
Re: Seatbelt Recall
I contacted Collin and unfortunately, I either hit a brick wall, or my IROC is one of the updated Camaro's. I gave Collin my vin number and he told me that there is absolutely nothing in the system for my Camaro. But, since my Camaro was initially purchased in the USA, the computer system in Canada is slightly different than the USA computer system. I can say Im rather happy though because my seat belts are in good shape. I really shouldnt be fussy. There is only a little fade in the red color, but not like other cars that have the buckle literaly flake away by rubbing it. Thanks for the help Dan.
Old Mar 20, 2010 | 12:31 AM
  #410
Re: Seatbelt Recall
If your car was included in the recall, which it should be (based on it's year), it shouldn't matter where it was originally purchased!! The computer system albeit is slightly different, it still should work, and give you a yes or no!! Say you were travelling through Canada, and encountered a warranty repair problem, I bet the computer would know about that!!!
If the recall was still outstanding against your car, I'm sure that you would be able to see it, when a dealer runs your VIN!!
My 1987 IROC-Z had the recall performed years ago, and the buttons show a little bit of fade after 18 to 20 years, it's bound to happen!!!
You could err on the safe side, and buy a set of replacement buttons, just in case!!!
Old Mar 20, 2010 | 04:36 PM
  #411
Re: Seatbelt Recall
Thanks Dan,
Did you get any satisfaction???
or
Old Mar 21, 2010 | 02:19 AM
  #412
Re: Seatbelt Recall
I just going to invest in a whole new seat belt system. The upper side of my seatbelts are bad anyway. Driverside doesnt lock when I yank on it to see if it locks. Better safe than sorry huh.
Old Mar 21, 2010 | 04:34 PM
  #413
Re: Seatbelt Recall
GM?? still has replacement seat belts available, however, your colour choice is very limited (Gray), and you may not get a complete set!! The price is also through the roof!! Back in November, when I had my little mechanic problem, the dealer (Colin) got me a replacement seat belt for the driver's side (retractors, and belt), but the price was $514.00 CDN!! No thanks on that one, besides the colour was wrong!!
The "yanking trick" is hit and miss I do believe!!! Something to do with the angle?????
Old Mar 22, 2010 | 12:30 AM
  #414
Re: Seatbelt Recall
WOW. I can buy a beat up IROC-Z for that kind of money. I'll pass.
Old Mar 22, 2010 | 12:51 AM
  #415
z28_87Camaro's Avatar
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: Seatbelt Recall
or
Well Collin confirmed that my camaro was indeed apart of the recall, and was still open for my vin. He looked into the parts, and like you said, said they were still available through the US. So I took that back to my dealer here, and they are gonna put the order through and see what happens. I guess I'll know sometime this week or next. Will keep you posted though. If they can't get it, I'll just order them through Collin and I'll pick them up next time I pass through Chilliwack.
On a different note, did you pay for your recall to be done? or did the dealer do it free of charge. There's been talk on here about it only being valid for 10 years then you have to pay for it to be done. However, us being in Canada, sometimes luck out? or visa-versa. lol.
Old Mar 22, 2010 | 10:12 AM
  #416
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Seatbelt Recall
Wow, wish i was in canada, i'm in the states and no dealer wants to do anything for my car that was confirmed an open case through GM's help line and dealer computers. I would do the work myself, i just wanted the parts to fix the damn things. This sucks.
Old Mar 22, 2010 | 11:43 AM
  #417
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Seatbelt Recall
I'm pretty sure this recall would be handled under the "old" GM, or Liquidation Motors. No doubt the dealers know that they will never be paid for any of this type work and creating good will with third gen Camaro owners is probably not a high priority with them. Heck, dealers I've dealt with in this area didn't care about goodwill with new vehicle owners, which is probably why they are out of business.
Old Mar 22, 2010 | 06:46 PM
  #418
Re: Seatbelt Recall
It was going to be done free by the dealer, however, my recall was done free by me!! (see my first? post in this thread about my ordeal) It cost me $27.00 in junk yard parts to fix the mechanics handy work!!
I have seen JT the Administrator/Webmaster's post #304 in this thread with the recall letter, and in the recall letter it states "Your dealer will perform the necessary repairs anytime during the life of the vehicle, at no charge to you"!!
Why would they make you pay for their fault?????
Old Mar 22, 2010 | 07:09 PM
  #419
Re: Seatbelt Recall
Hello 84redta!!
Part # 14097930 Group 14.875 Push Button Kit approx $10.50 CDN!!
Old May 9, 2010 | 12:43 AM
  #420
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Seatbelt Recall
Does anyone know if there was a re-call on the recoil system for my 88 camaro? The recoil doesn't work properly, so i'll need to get a new seat belt system installed.
Old May 10, 2010 | 12:49 AM
  #421
Re: Seatbelt Recall
Hello Crusin' 1980's!!
Are you pretty handy at the mechanical things???? I do believe that there is a fix for seat belts that don't retract!!
Required disclaimer: All seat belt work that you do based on my "info" is strictly at your own risk, I in no way take any responsibility or liability for any injuries/death that may occur as a result of any modifications that you perform on any of your factory installed safety restaint systems, based on my "info".
Here goes: There is a mechanism that prevents the seat belt from tightening up against you, kind of like an old roll up blind. This is where the problem lies, providing that your return spring is not broken. You have to determine this via an inspection of your retractor. On one side, you have the clock spring for making the seat belt retract, on the other side you have the roll up blind gizmo. The roll up blind gizmo eventually stops working, due to weak spring, gummed up, jammed, etc. Once you pull the seat belt out as far as it will go, and this gizmo engages, it's stuck, you can not pull on the seat belt any more to make it release. The trick is to lift the wire on the end of this gizmo, out of the catch that it's jammed into!! Once you do this, and your retactor spring is not broken, it will wind up like it was a new belt!! I believe that this gizmo, can be eliminated altogether, and your seat belt will still function, as intended when required, as the inertia locking mechanism, is not connected to this part in any way whatsoever!!
The one function that you will lose, is the roll up blind effect, the seat belt will operate as a seat belt from the 1970's, where if you moved forward, the seat belt moved also, and when you moved backward the seat belt did also!! It will never stay slack, like it does sometimes now, where you would have to manually pull on it to make it retract!!
You can check all this out for yourself at the junk yard!! Examine a seat belt retactor from a 1970's car, it has the inertia lock, and the retractor spring, but not the roll up blind gizmo!! They worked then, and they work now!!
The other thing about the roll up blind gizmo is that I do believe that it also "limits" the speed of the belt moving forward, which causes/helps it to lock up also, giving it a two pronged attack on holding you back into the seat during a frontal collision!!
I have personally taken a jammed drivers side seat belt out of a 1986 Camaro, and popped the cover off of the roll up blind gizmo, and as soon as I released the wire out of the catch that it was jammed into, it retracted just like it was brand new!!! I replaced the wire back into it's slot, pulled the seat belt all the way out, and it promptly jammed again!! The second time, I removed the wire, the seat belt retracted again like it was brand new, and this time I left the wire out of it's slot, and everytime that I pulled on the seat belt it came out, and retracted like it was brand new!!
You can fix the retractors, even the roll up blind gizmo!! As long as the seat belt is in the retracted mode, it will stop you, as it's functional!! If the seat belt is jammed in the fully extended mode, you will stay in the seat, but your going to hit the steering wheel for sure, as nothing is holding you back!!
P.S. If you are driving your car with the seat belts in the fully extended mode, trying my "info" I believe, can't make it any worse for you!!!
Old May 17, 2010 | 04:29 PM
  #422
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Seatbelt Recall
That same thing happened to me with my 87 IROC but the guy said it was already done to my car too. But that doesnt make any sense because my passenger seatbelt wont tighten it just hangs loosely unless you yank on it then it goes tight.
Old May 17, 2010 | 06:26 PM
  #423
Re: Seatbelt Recall
Thats a different issue. This thread concentrates on the deterioration of the red release button. Your issue is related to the retractor. But I got the same problem. My driverside belt doesnt lock even if I yank the junk out of it.
Old May 19, 2010 | 07:33 PM
  #424
Psycho139's Avatar
Car: 1985 Iroc
Re: Seatbelt Recall
I need to check mine out but not going to let the dealership try and screw me. I'm going in with this http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm let them say there is nothing they can pull up...
Old May 19, 2010 | 07:52 PM
  #425
Stephen's Avatar
Car: 87 GTA
Re: Seatbelt Recall
NHTSA CAMPAIGN ID Number: 90V105000
NHTSA Action Number: EA90001
Here is the 109 page document in pdf format, whi also shows the ranges of VIN #s that are included in the recall.
http://nhthqnwws111.odi.nhtsa.dot.go...-90V105-NN.PDF
Old May 29, 2010 | 01:08 AM
  #426
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: Seatbelt Recall
i talked to pontiac earlier and they tried telling me my vin didn't fall between the break points. i had just woke up when they called and just said whatever and hung up. then after i woke up i went back to looking at the pdf and because my vin is hn22***6 it falls between the vin break points for year 1987 plant Norwood begining hn200001 up to and including hn253013. that little bit of information come from page 2 of 8 in the 1990 dealer product campaign bulletin. subject product safety campaign 90-c-03 seat belt buckles. date 06/90. models affected 84-90 pontiac firebird that document is on pages 9-15 of the 109 page pdf. i sent them an email similar to what i just wrote and they have not wrote back yet. anybodie got any suggestions what i should do about this. my seat belt buttons are a chalky pinkish white.and they don't always click or stay clicked.so i know they were never took care of.
Old May 29, 2010 | 02:43 PM
  #427
Re: Seatbelt Recall
Sucks but you may have to copy and paste the Memo Header, then copy and paste the most important info on a spreadsheet or word document and print (with the website noted if they dont believe you). Then head over to the Dealer and pound your proof on the service desk and say, "Isn't customer satisfaction your priority?" Then spill your story. Having a hard copy of such info can be very effective. Good luck bro.
Old Jun 2, 2010 | 11:58 AM
  #428
okfoz's Avatar
Re: Seatbelt Recall
Buy a kit, there pretty cheap too... One kit I saw came with the tool to remove the button...
Old Jun 2, 2010 | 01:58 PM
  #429
jjones88's Avatar
Car: 1988 Camaro
Engine: 2.8L
Re: Seatbelt Recall
Hey everybody,
My first post but I thought I'd inform everyone that I called my local Chevy dealership today and got a lady who looked up my VIN and acknowledged the recall and set me up an appointment.
This is in East TN and they are doing the push button and release mechanism free of charge. Even replacing with proper gray color.
Josh
Old Jun 23, 2010 | 06:41 PM
  #430
Nasphreak29's Avatar
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
Re: Seatbelt Recall
Called the GM line, they said they either my car had already had it done or that didn't need it done. She went on to say that "I show no recall at all for any Camaro of those years". So i completely discredited what she said.
I then called my local Chevy dealership. When I told them what I was calling about they just informed me that most of the advisers had left for the day and for me to call back tomorrow to ensure they have the parts then i can set up an appointment.
So I guess my local dealership has dealt with several recalls on this cause she knew exactly what I was talking about.
Old Jun 27, 2010 | 01:39 PM
  #431
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
Re: Seatbelt Recall
funny thing i just took my car inn at local chevy dealer yesterday for this recall i got all new seal belt buckles
Old Aug 11, 2010 | 12:50 PM
  #432
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
Re: Seatbelt Recall
my vin falls within the last 8 breakpoints, but 2 dealerships i called locally had no clue, one even said my vehicle is NOT effected, LL125992, am I in or out? on phone with chevy now and they cant find either. did the free seat belt wave crash?
Old Aug 11, 2010 | 02:13 PM
  #433
Re: Seatbelt Recall
I fell within the range and the GM dealer has no record of repair or such. Even the recalls that went out in the early 2000 didnt affect my IROC, and I still was one of those affected. But I said the heck with them.
Old Aug 12, 2010 | 11:20 AM
  #434
Phoenixfire1989's Avatar
Car: 1989 Formula -1986 T/A
Engine: 305 V8 FI- HO350 V8 carb
Transmission: 5 speed manual- Automatic
Axle/Gears: stock - unsure
Re: Seatbelt Recall
Originally Posted by 87CamLT
I just wanted to update everyone on my progress. Two weeks ago after i called Chevy for the fourth time they led an investagation into the dealer. They told me to bring the car back so they can check for a compleation sticker. Surprise, they didn't find one. I then was told to call back two days later. After i got home that day i recived a phone call from Chevrolet. They told me it should go through and to contact the dealer, so they can take down some more info about the car so they can preform the work. The next day i called the dealer and i was told they didn't get the offical ok. They told me to expect a call in one or two days. By the third day i still didnt recive a phone call. I called them and was told that the head guy at GM who takes care of recalls still didn't approve it, and to expect a call in a few days. It has been a week and i am tired of the BS. I am going to Call Chevrolet today and let them know that if this isn't taken car of I am going to contact who ever it takes to get this done. I live in The NJ area and can contact the NY FOX station. They have a segment known as the problem solvers where they bring un wanted publicity to people such as the dealer i am dealing with. I in no way blam Chevrolet for this, this dealer is know to blow off old recalls. I have a friend who worked there and can testify to that fact.
Let me guess? Was it elkins? XD
Old Aug 20, 2010 | 01:31 PM
  #435
Camarillo's Avatar
Car: 1990 RS Camaro
Re: Seatbelt Recall
They seem to only want to replace my drivers side harness, with flame red, they say that its all that is available. Wont touch any other belts. FYI complain about all belts coming undone and MAYBE they will change all...
Now I guess I will have to buy flame red belts for the rest of the car. At least my car is bright red, so the flame belts shouldn't clash too much
Old Oct 24, 2010 | 04:53 PM
  #436
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
Re: Seatbelt Recall
I own an 88 camaro too, and my passenger belt will not retract . A crappy position, but maybe a new re-call and free repair?
Old Nov 1, 2010 | 02:16 PM
  #437
camaro87jb's Avatar
Car: 87 Iroc z
Transmission: AT
Re: Seatbelt Recall
i got the big "Sorry nothing in our system" answer from my local Chevy dealership. My belts work, but the buttons are very faded and since my car is low mileage.. im worried they will fail as they are used more.
Old Nov 1, 2010 | 08:39 PM
  #438
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Seatbelt Recall
Anyone have a picture of the removal tool used to replace the buttons?
Old Nov 9, 2010 | 11:16 PM
  #439
Re: Seatbelt Recall
Hello RoosterC!!
Check out my post #421 in this thread, you can fix your seat belts!! No need to search for another one!!
I have personally done the "fix" in my post #421, three times, and all three times I have met with success!!
I just did one last night in my garage, and it took all of about 15 mins to do the "fix"!!!
I took some step by step pictures also, hopefully, I'll be able to post them, this weekend!! (I have to figure out how to do this) Maybe it will be good enough for a sticky!!
Read my post, also the disclaimer, my seat belts work perfectly, they only lack the "comfort feature", and the "comfort feature" is for the weak people who can't handle the tension of the retractor spring!!
Old Nov 9, 2010 | 11:26 PM
  #440
Re: Seatbelt Recall
Hello tom3!!
You don't need the removal tool to do the button replacement!!
I did mine with a small (1/8 inch) flat tip screw driver!!
15 mins to do all four!!!
A word of caution, go real easy on the plastic cover, don't use it as a pivot point, or you could end up with a broken cover!!
Use your hand/finger to protect the cover, and gently pry up on the old button at each end, you should see a little slot at each end, put the screw driver in there, and gently pry up!!
The button should pop off the black plastic button retainer!!
Re-assembly is straight forward, push the new button down gently on the black plastic button retainer, it should just "click" as you push down, make sure that you line it up straight!!
Old Nov 16, 2010 | 11:10 PM
  #441
Re: Seatbelt Recall
Hello All!!
The GM instructions for the seat belt button replacement can be found here at this link, PDF pages 65 -73 !!
http://www-odi.nhtsa.dot.gov/acms/do...-90V105-NN.PDF
It seems that Stephen already posted this at post # 425, oh well, sorry to waste space!!!
Old Dec 19, 2010 | 09:33 PM
  #442
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: Seatbelt Recall
This is an old post but I thought I would throw this out there. I was doing some work for my local Chevy dealer and asked a service advisor about the recall. He pulled it right up. It looks like getting the correct color is going to be a problem though. He can still get rear seat ones in gray, but not front. He said he will get me a pair for the front, but can't promise what color. It's to bad that some places give people such a hard time. It took 5 min. He just gave the list of part numbers to the parts guy to find out what he can get and will call me on Monday. Depending what color he can get, I may have a new set to sell. Red in a gray interior will not work!
Old Dec 19, 2010 | 09:59 PM
  #443
Re: Seatbelt Recall
My IROC has several recalls but my dealer claims that I don't qualify. The latest recall was a light issue in 2003. I got my IROC in early 2002. They said I or somebody already claimed the recall. BS. And here you are with the free seat belt that some of us are denied, while trying to make a buck.
Old Dec 19, 2010 | 10:10 PM
  #444
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: Seatbelt Recall
Hey, I'm not trying to make a buck. There are a lot of people here selling seatbelt parts. If I can sell or trade the one I get so that I can get the correct ones that's all I want. It is my son's car so I just want it to be safe. Take a second before you judge me man. I'm not out to gouge anyone her. Many people have helped me. I just want to get safe, working, correct color seat belts. If I have to sell the ones I get to do it, I will.
Old Dec 19, 2010 | 10:18 PM
  #445
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: Seatbelt Recall
The advisor I work with is great. I have worked with him for years taking care of our fleet vehicles. Gateway Chevy (701) 282-5522. His name is Robin. Give him a call. Maybe you can at least get the proof you need that there is a recall on your car.
Old Dec 19, 2010 | 10:19 PM
  #446
Re: Seatbelt Recall
ur sons car? Well then. My apologies. Please excuse my previous post. Its just really frustrating when the Highway safty board says that we fall in the affected range but once we visit the dealer, they claim no such recall.
Old Dec 19, 2010 | 10:22 PM
  #447
Re: Seatbelt Recall
Great. Ill give that number a call and talk with Robin. Again, my apologies. Thanks.
Old Dec 19, 2010 | 10:29 PM
  #448
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: Seatbelt Recall
No problem. I can imagine you are very frustrated. Hopefully he can at least fax or email you the documentation you need and you can go to the dealer that is giving you so much trouble and shove it up his a@#! You will be calling central time so early for you won't be early here. Robin is good so he is very busy. I hope he can help you.
Old Dec 19, 2010 | 11:08 PM
  #449
Re: Seatbelt Recall
Thanks man. I appreciate it. Peace.
Old Dec 20, 2010 | 02:43 PM
  #450
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: Seatbelt Recall
Talked to my service advisor today and my buckles are on order. I used a document posted on TGO that has all the recall info. Individual buckles are hard to come by, but the part numbers for the kits were available. They are discontinued from GM but they did a search and there are dealers all over the place that have them. I saw a dealer in AZ that had 3 sets of Gray. The kits have both front and rears. Keep after the dealers that say they can't get them. So far it has taken my dealer about 20 min to find everything I need, and they were grateful for the sheet that had the kit numbers on it.
