different underdash trim panel for manual cars?
Old Jul 2, 2006 | 05:31 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I'm finishing up my auto to T-5 swap, is there a difference in the trim panel above the pedals between the auto cars and those with 5 speeds?
I can't seem to squeeze mine in as it collides with the clutch pedal.
I don't recall seeing this mentioned in any of the transmossion swap posts.
Old Jul 2, 2006 | 05:58 PM
Engine: ZZ4 TPI
Never mind...I figured it out.
There is a cut-out guidline molded into the back side of the panel, it was covered up with glued on foam.
Old Jul 2, 2006 | 05:59 PM
j dezzy's Avatar
Car: 87 TA
Yup. The under dash trim for a manual has a cut out for the clutch pedal to slip into.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
