noise coming from center dash on startup
Old Jul 3, 2006 | 08:41 AM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
what's up guys. I need a little help with this one. I searched for info on this problem but I guess not good enough cause I could not find the answer. I have a 88 iroc. when I start it up I hear a gurgle noise coming from the center of the dash.Then it stops and I do not hear it again until next start up. Any ideas??
Thanx!!!!
Old Jul 3, 2006 | 01:03 PM
GameRS's Avatar
Car: 1990 Camaro RS t-top, '01 BMW 325i
Engine: L03 V8, 2.5L I6
Transmission: 700r4, Steptronic 5-spd
Axle/Gears: stock, stock
That almost sounds like the heater core. Maybe there is some air trapped in the coolant or the core is starting to leak.. I'm not sure on this though. My 96 Neon has that same noise and its because the heater core has started leaking. Try turning the heat on in the car and listen for the noise.
Old Jul 3, 2006 | 01:23 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
ditto. same problem with my old Mustang adn it had the same solution.
Old Jul 3, 2006 | 10:01 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
thanx I'll look in to it!
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
B_Dubya
Aug 26, 2015 05:09 PM
