need steering wheel help
Old Jul 21, 2006 | 01:45 PM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I have a 91 RS with air bag and my steering wheel is in bad shape, would like to get an aftermarket Grant but they stopped making them for this car in 89 due to the air bag. What have you guys done to change out or do any of you have any ideas you can give me so i can change it out. thanks
Old Jul 21, 2006 | 02:09 PM
j dezzy's Avatar
Car: 87 TA
is your issue in removing the airbag? or needing a steering wheel?
Old Jul 21, 2006 | 02:40 PM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
i would like to replace the steering wheel with an aftermarket one if possible
Old Jul 21, 2006 | 03:58 PM
j dezzy's Avatar
Car: 87 TA
are you trying to find an aftermarket steering wheel or put one on?
Old Jul 21, 2006 | 04:04 PM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
both
Old Jul 21, 2006 | 04:17 PM
j dezzy's Avatar
Car: 87 TA
well, I'm not too big on tracking down aftermarket steering wheels. I like the stock ones, preferably the 82-84 style. But I've seen some good looking ones at yearone.com. you could check there for one. I know they have some specificly for our cars. getting that airbag wheel off isn't hard. first you need to buy/borrow/rent a steering wheel puller. then disconnect your battery. I also suggest pulling the airbag fuse too. on the back of you steering wheel there is going to be 4 screws holding your airbag on. take them out and then disconnect the wires from the column. place the airbag somewhere SAFE. you don't want it going off accidently. then take the retainer ring off the big bolt right in front of you and then use a socket wrench to take off the big nut. hook up the steering wheel puller and yank that old wheel off. remember when you're buying your new wheel that you'll need to buy a new connecting neck too for the wheel. some come with ans other without....mostly without from what I've seen. toss that on and you're done...unless the little SRS light bothers you. Since you no longer have an airbag it will always stay on. jsut do like the rest of us and yank the little lightbulb out, you don't need it anymore.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
