Window Motor Replacement
Old Aug 11, 2006 | 09:37 PM
Marksp's Avatar
Car: 1992 Z28 Conv.
Axle/Gears: 10 bolt, 2.73 posi
Hey guys I'm in the middle of replacing my window motor, and I found some pretty good instructions on the web. Check it out...
Retrofitting Power Windows into 3rd generation F-Bodies
btw: Replacing the window motor is a complete pain in the ars.
Old Aug 11, 2006 | 10:31 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
theres a way easier way by not taking the tracks and every thing out. And no rivit gun needed. Drill through the inner door panel metal to expose the 3 rivits holding the motor on the regulator. There is a template around on this site that you print out and you tape to the door. I shows where to drill the holes to expose the rivits. You are just going through the door metal at this point to get a visual on the rivits and drill them out in about 2 seconds per rivot. the whole motor will fall to the floor of the door. Then put in the new motor lining up the gear teeth and using the bolts that come with the motor. Tighten them good and lock tite! Plug it in and be proud and have a beer. Slap the door panel back on. You could grease the tracks and whatever ya think needs it before replacing the door panel.
Good luck,
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
