putting in 4th gen dash to 3rd gen iroc help please
Old Aug 15, 2006 | 04:49 PM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
I am putting a 4th gen dash into a 3rd gen Iroc where do I start please help wiring and everything does the 4th gen bolt up the same what am I in for
Old Aug 15, 2006 | 08:20 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
i hate it when people say this but its every where i might even help you and give you a link
Old Aug 16, 2006 | 12:02 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I would advise you NOT to do this.
Old Aug 16, 2006 | 12:40 AM
Car: 1998 Z28
Transmission: 460le
why not
Old Aug 16, 2006 | 11:00 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Aaaaaand why is that? give the car a newer more modern look and feel. Mine is still a work in progress, but I like it ...
Dayton F-body Association :: View topic - New Project....
Old Aug 19, 2006 | 08:05 AM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Do the and them go for a change. My car feels like I'm diving a new car now. It will make the car look so much better. Whatever you do just keep all the factory parts incase you decide to switch back somewhere down the road.
Good luck
Old Aug 20, 2006 | 04:08 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
The swap is easy as pie. But i did mine in a t/a so yours is going to be different. I even started swapping in 4thgen a-b pillars so far the passenger side is done.
heres a photo , everything works includeing vents ,etc.
Attached Thumbnails putting in 4th gen dash to 3rd gen iroc help please-picture-201.jpg   putting in 4th gen dash to 3rd gen iroc help please-picture-203.jpg
Old Aug 21, 2006 | 12:38 AM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Has anyone ever put a 3rd gen dash inside of a 4th gen?
Thats one thing you could do to improve your 4th gen I guess.
*im biased*
Old Aug 21, 2006 | 01:27 PM
just2quickz28's Avatar
Car: 86 IROC
If you are going to do it DO IT RIGHT, the car i bought to replace my 85 had a half assed 4th gen dash install, the brackets were cut jagged, dash wasnt attached very well and the steering coloum was loose and most of the wiring was wrong. and worse of all the dash that was used was cracked to start, i deceided to trash the dash and swap back to a 3rd gen, which is still in progress
Old Aug 23, 2006 | 09:56 PM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
when you did this swap, did you keep the original steering column? and how much cutting/fabricating was involved? thinking about doing this to my 92 rs
Old Aug 24, 2006 | 05:31 AM
vindoo's Avatar
Car: 89 Formula 350
Looks like quite a project...
IMO, they dont like quite "right" in our cars. They are too roundish looking to be in a more squared off third gen. Just my opinion though....
Old Aug 27, 2006 | 12:17 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Yes ,original steering colum was used. The 4thgen dash colum mounts slide right into place on the 3rdgen no fabrication reqired. Wirieing was easy , all of the diagrams are posted on here. You have to bend or cut the third gen dash brackets off , i bent them in case I ever wanted to swap back dashes. For heater controls I have kept the stock thirdgen ones to avoid hassles. For the air box you basicley make the 4thgen air box look like the third gen box with a little trimming and adding a bit of foam. When its all in you can actually glue or duct tape foam if you have any leaking air areas. Mine works perfect this way. The top mounts of the dash all lineup with the third gen mounts execpt for one. You just drill a hole to accomidate it. If you do the swap I would gladly send step by step pics of what you need to do. Its really easy and the WOW factor I get from people is cool . Lastly you need to takre a good 8-10 inches off the 4thgen dash top. I simply measured from the middle of the dash when it was moutned ,grabbed my old third gen dash pad used it as a template and marked were I needed to cut.
Old Aug 27, 2006 | 08:37 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
hey gnarly boarder can you send them picks to me please cause im
Old Aug 29, 2006 | 04:07 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
sure!
Old Aug 30, 2006 | 08:41 PM
Engine: LB9
yea if you wouldnt mind sending those to me it would be awesome Thanks for the help. my email is Bill_larue1972@yahoo.com
Old Sep 1, 2006 | 05:09 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
i dont know but i dont have an email (or should i say it donnt let me in) so how could i get them
Old Sep 3, 2006 | 06:28 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Sorry I totally forgot about all this. I will send pics out tommorow of mouting points ,etc.
cheers
Old Sep 4, 2006 | 01:03 AM
Engine: LB9
that would be frickin awesome. thnx dude, my email is a cpl posts up ^
Old Sep 11, 2006 | 08:04 PM
T56ThirdGen's Avatar
Car: 83' Z28 Camaro
Engine: Cammed 4-bolt main 350
Axle/Gears: 4th gen rear 3.42 gears
hey i have a camaro and i have a dash out of a 1997 ss camaro with all the trim panels a pillars vents, trim plates , console (it already has a T56), and the 97 guage cluster. i was wanting to know if you know if you can hook up that guage cluster and if you could send me those pics too i would really appreicate it
Old Sep 11, 2006 | 08:05 PM
Car: 83' Z28 Camaro
btw my email is matthewtollison@hotmail.com thanks again!!!!
Old Sep 11, 2006 | 08:22 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
knarley and i talk ona regular basis, and helped eachother out on the 4th gen swap, i installed one to. i dont have much pics im in the middle of the whole 4th gen interior swap but here is a video i took in my car with the 4th gen install, FYI there is no deck installed yet, and i have yet to install the top dash piece, the pillars, and the air bag cover, or the cover under neath the steering column as i need to install the trunk switch. this is just mock up but all gauges work. There was no cutting, except the plastic heater/defrost vent piece in the back, and it pretty much bolted right up. 3-4 holes up top lines up, and the 2 bolts for the steering column lined up.
Video - just got the old trans am back
Old Sep 11, 2006 | 10:00 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Man the city sucks...
Old Sep 12, 2006 | 08:34 PM
Car: 83' Z28 Camaro
hmmmm, what about the hvac controls has anyone tried to make the fourth gen controls work with a third gen heater box? i think the vaccuum would be the easy part just making the hot-cold cable work.... oh and would you have a diagram of how you wired your guages? what about the headlight switch? i think this wouldnt be too hard but i havnt looked into it yet. any heads up on that? one more thing how do you remove the airbag and retain the cover on top of the dash? THANKS!!!!
Old Sep 12, 2006 | 09:24 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
you cant remove air back from behind i tried to remove it from behind, but there are 2 bolt holding it in on top.
i have the hot/cold cable i just need to mount it, check out d10pins post he has specific details. but my heat comes out all my vents, and also all wiring works.
Old Sep 15, 2006 | 08:30 AM
fureyj8's Avatar
Gnarly boarder could you send me the instructions on how to swap. I'm considering doing the swap into my Z28. My email is fureyj8@aol.com. Thanks
Old Sep 15, 2006 | 09:40 PM
PDye's Avatar
Car: 1992 Camaro RS
Engine: 513 BBC
Transmission: 700R4 (ummm yeah stock)
Axle/Gears: Junkie ones....
This bandwagon looks like it needs jumping on....can you send the photos my way as well?
phil.dye@us.army.mil
Thanks,
Phil
Old Sep 17, 2006 | 01:35 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
anyone who posted there email has mail
Old Sep 17, 2006 | 04:28 PM
Engine: LB9
thnx gnarley, your frickin awesome.
Old Sep 17, 2006 | 07:21 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
i could use the pics too bro lol, way2fast4stangs@sbcglobal.net
Old Sep 18, 2006 | 02:24 AM
dlvalure's Avatar
Car: camaro rs (a tru sleeper)
Transmission: turbo 350
im really considering this swap also if you can send me sum pics and sum additonal information to my email i would gladly apperiate it....derrickvalure@yahoo.com
Old Sep 18, 2006 | 04:26 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
hey gnarly boarder got my email its sorry it took so longskaterdrew_69@yahoo.com
Old Sep 18, 2006 | 10:36 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i'd love to have th pics also. Been thinking of doing the swap sometime next spring. deliriousami@aim.com is the email
Old Sep 21, 2006 | 02:49 AM
blackcrow64's Avatar
Car: 92 Firebird - 97 Talon TSi AWD
Engine: Firebird: 3.1L - Talon: 2.0L
Transmission: Firebird: 700r4
I am just curious as to how hard it was to install the 4th gen center console... My old 3rd gen console has finally wore out and I figured I might as well do the swap now while its all apart...
I have an automatic and didn't know how closely things would line up in the aspect of the shifter...
Old Sep 21, 2006 | 09:11 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
without the 4th gen dash there will be a gap, but they bolt in the existing holes on the floor. the auto will need to be modified and the manual is pretty much direct fit.
Old Sep 21, 2006 | 10:12 AM
How much of a gap will it leave between the console and radio pod? I'm assuming thats where the gap will be that your talking about... I did a lot of reading of the existing threads about this swap last night and I noticed that people did have to hack off a little bit off the underside to allow movement into park... Is this the same modification your talking about?
Old Sep 21, 2006 | 11:26 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
just where the shifter mounts on the console, you may need to modify it a bit to fit. otherwise it does, or you could just pop out that piece altogether i believe it removable, i just went with the manual console. im too lazy.
Old Sep 21, 2006 | 11:48 AM
Ok, I think I'm gonna do the swap here soon... I might try modifying the shifter or swapping it with the 4th gen one also.
Old Sep 26, 2006 | 04:29 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
hey it would be awesome if i could get some pics of this gnarley boarder!!...i just considered it and it would be kick ***!!! thanks
Old Sep 26, 2006 | 09:37 PM
wlsmoku's Avatar
Car: 1988 GTA
I am totally in the middle of this project, and would REALLY appreciate pics to make sure I'm doing everything correctly....please and thank you!!!!
3inman@sbcglobal.net
Old Sep 26, 2006 | 11:31 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Transmission: 4L60
Why dont you just post the pics up here?
Old Oct 10, 2006 | 07:43 PM
92camaro350's Avatar
hey can you send me some pics and extra info thanks! mxzrider500@gmail.com
Old Oct 16, 2006 | 02:29 PM
  #42
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
same here.. looks like a big project btu need some visual tips... Yahoo!
tpiterror@yahoo.com
Old Oct 16, 2006 | 07:35 PM
  #43
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
The basic dash swap isn't difficult...just don't be one of those guys that throws the dash in with a few screws and thinks they are done.
Old Oct 16, 2006 | 08:39 PM
  #44
xcrunnr120's Avatar
Car: 87 trans am
if anyone has pics or a description of how to install the 4th gen dash in a 3rd gen vould you send it to me. jbenne16@dtcc.edu
Old Oct 16, 2006 | 09:26 PM
  #45
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
still a work in progress but everything works.
Old Oct 17, 2006 | 11:42 AM
  #46
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
does anyone know what size gauge fits in the 4th gen dash vents?
Old Oct 18, 2006 | 10:56 AM
  #47
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Great job guys! I thought about putting a 4th gen dash into my 87....but I like the older looks better. I just added all autometer gauges to freshen it up a bit. I have to admit...I thought installing and wiring the LS1 was pretty easy...bu trying to rewire a dash intimidates the heck out of me.
Justin
Old Oct 19, 2006 | 07:09 PM
  #48
Firebat's Avatar
Here are some things I did on my dash swap(still a work in progress too):
Make sure you get the bracket that goes along the bottom of the 4th gen dash.
This is what i did to attach that bracket to the car. You have to cut out those small brackets that are welded to the thirdgen car but not completly cut them. Then, get a 4" corner iron. Bend it, cut it, grind it down, or whatever to get one end to lay flat up against the dash bracket and one to what's left of the bracket on the car. Drill and tap holes on either the brackets or the corner iron, whatever works best but only tap one. This way you can just bolt on the brackets together. Here are a few pics to give you an idea. Menards or most hardware stores should have this 4" corner iron. I plan on painting it black or covering it up with something later.
PICS on the passenger side:
For the bottom hush panels I had best luck using the 4th gen drivers side hush panel and the thirdgen passenger side hush panel.
For the thirdgen p.s.h. panel, I know for sure I had to cut where the glovebox would go in at so the glovebox would fit.
For the forthgen d.s.h. panel, I had to cut in the corner, the corner where you would have the clutch, where it touches the back carpet.
Might have had to cut a little bit in other spot but can't remember.
Passenger side:
Old Oct 29, 2006 | 09:36 AM
  #49
sauercream84's Avatar
I would also like detailed pics of the swap if someone would send them to me. My e-mail is sauercream84@hotmail.com Thanks
Old Nov 2, 2006 | 11:14 AM
  #50
Boosted Bird 85's Avatar
me too if you wouldnt mind. BoostedBird85@aol.com
