91 Firebird Center Console ?
Old Aug 17, 2006 | 01:48 AM
TransAmMike's Avatar
Car: 91 Firebird
Engine: 3.1 v6
Transmission: Automatic
How do I get the center console cover up? i can pull most of it up but it seems to be stuck near the cigarette lighter, which i think might be holding it down. anyone know how to remove the cigarette lighter socket?
Old Aug 17, 2006 | 02:50 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
you have to pull out the ash tray, and under that there should be a bolt/screw under that.
Old Aug 17, 2006 | 01:16 PM
Car: 91 Firebird
Engine: 3.1 v6
I pulled out the ashtray and theres no bolt or screw there. It seems like its being held down by the cigarette lighter.
Old Aug 17, 2006 | 04:56 PM
zeppelin5000's Avatar
Car: 1991 GTA Trans Am
Engine: 355 TPI
Transmission: 700R-4
The only scres that hold the center console down are 2 screws inside the console compartment towards the back of it. The plastic trim piece that goes around your stereo and A/C controls probably needs to be removed first. It should pop right out. Then if you have the stock shifter, you need to take off the shift ****. Then, try and pull the console out up, and towards the rear.
Old Aug 22, 2006 | 01:56 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
I had this problem also, try and disconnect the wires to the cigarette lighter then do some pullin. In my case the connectors were hooked on something in there.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
