weatherstripping
Old Sep 12, 2006 | 04:59 PM
north_oakland's Avatar
Car: 1989 Camaro
Engine: 2.8L
weatherstripping
Im not sure if this is the right section to post this but I have an 89 camaro with t-tops and I have alot of leaks all around my car and I was thinking about taking my var somewhere to get all new weatherstripping put in. But first I wanted to know if it was hard to put it in yourself or if any1 had a guide to do it yourself because If it is not that difficult I will try and do it
thanx 4 any help
Old Sep 12, 2006 | 05:50 PM
84matrat's Avatar
Car: 1984 Camaro
Engine: 305...soon to be 383
Transmission: 700R-4
there are four adjuster plates around the t-tops so you can get more downwards clamping pressure on the t-tops. Try tightening these up if you are looking to try and save some money. if not, do a search... i would recommend getting it done correctly either route you take. i believe (correct me if i'm wrong) that gm kits come with fairly detailed instructions for installation.
Old Sep 12, 2006 | 07:04 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Are you fairly good with working with your hands? It's not rocket science, just takes a lot of patience and for the t-tops especially a lot of important cleaning/prep work before you put the new seals in.
Old Sep 13, 2006 | 12:09 AM
Car: 1989 Camaro
Engine: 2.8L
Its not leaking really from the t-tops its more where the t-top and door meet and also it leaks all around my rear window and it has a weird leak along the front side of my door.
Old Nov 1, 2006 | 12:02 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
on one of my ttops the weather stripping in starting to come off.is there any way i can place it back in without having to take the whole thing appart??
Old Nov 1, 2006 | 09:43 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
u have 2 explain where onthe t-bar or on the ttop itself?
Old Nov 2, 2006 | 08:42 AM
Car: 86' Z28 Camaro
its on the passenger side were the window meats the ttop.a little flap is starting to come off
