carpet removal
Old Oct 13, 2006 | 12:38 PM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
carpet removal
Does anyone know if i need to remove the console to replace my carpet or can i just cut it out.
Old Oct 13, 2006 | 12:58 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
if i remember correctly i think you got to take the console out. i have a 5spd so it may be different/
Old Oct 13, 2006 | 01:05 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Remove the console. Might as well do the job right if you are going through the trouble of removing the carpet.
Its not that big of a deal.
To save yourself some trouble. Once you have your plasic top cover off, pull the pin and disconnect the E-Brake Cable from the E-Brake Lever.
It will make the process of pulling the E-Brake to the completely verticle position easier.
Great thing about removing the console, you get to clean under it.
Old Oct 14, 2006 | 08:42 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
yeah i'd just go ahead and remove the console. takes all of 30 minutes. then its like a treasure hunt, you get to find all kinds of things from all the previous owners. french fries, loose change, cd's.
plus when you have that carpet out you can check for rust.
Old Oct 14, 2006 | 09:24 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It's like 3-4 bolts, should take about 5 minutes.
Old Oct 14, 2006 | 09:31 AM
Tobias05's Avatar
hmmm...accounting for the shifter plate, upper console, radio trim, radio, and HVAC, it took me about 30 minutes to completely remove the entire console assembly, including its components.
I guess I'm just slow. Your results may vary. haha
Old Oct 15, 2006 | 03:12 PM
{TKM}Tom's Avatar
Car: 84 Trans AM
Engine: 305 HO
Transmission: one that dont work so well
no it took me and a buddy about a half hr to do dont want to break anything even thou my console was already broke in about 14 place so i went out and got a new one, anyways when i got the carpet out there was like 4.00 in change and two keys lol the one looked like an origanal to the door didnt try it out thou
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MORREALE5
Sep 13, 2015 09:01 PM
Stroopwafel
Sep 11, 2015 06:38 AM
machinist21
Sep 5, 2015 03:03 PM
