Dash removal
Old Oct 16, 2006 | 10:28 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Dash removal
How hard is it remove the entire dash from an 89 IROC?
I would appreciate step by step instructions.
Thanks in advance to whomever feels like responding.
Old Oct 16, 2006 | 11:04 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
um...not to sure byt let me know about it if u find sumthn
Old Oct 17, 2006 | 05:26 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It's fairly easy.
1-remove the dash pad, the center console, and the speedo cluster
2-I found it's easier to remove the dash if you lower the steering column or pull the wheel
3-there are two bolts on the top of the dash near the corners (remove those)
4-there are like 4 bolts underneath IIRC they are 10mm so look for them
5-remove the dash
Old Oct 17, 2006 | 11:14 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
""4-there are like 4 bolts underneath IIRC they are 10mm so look for them""
Thanks for the response. What is IIRC?
Old Oct 17, 2006 | 11:38 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
IIRC means if I remember correctly
Old Jun 10, 2009 | 09:42 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Dash removal
What do you do with all the wireing?
Vintageracer
Jan 10, 2020 05:33 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
