need idea on how to remove the raised shift pattern square
Old Nov 8, 2006 | 07:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
I need to remove the raised shifter patern square on the shift plate, I have a rectangular aluminum 6 spd patern that I want to put there but its bigger then the square thats already there and the edges will overlap enough where it will look stupid. plus it will get ruined if the edges are like that. I need to shave the plastic down somehow w/o ruining the surrounding pattern of the plate. Got any good ideas? Im thinking the best is a very steady hand and a dremal with a sanding roll on it. I cant ruin this thing because we all know how rare and expensive they are to replace.
Old Nov 8, 2006 | 07:33 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I was going to suggest your idea, I know you can do it just take your time and be patient.
Old Nov 9, 2006 | 11:50 PM
Quasi-Traction's Avatar
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
I'll second that...might use a ruler/combo square and mark on each side how much you want to take off.
Old Nov 10, 2006 | 12:02 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Cut a square in something like say a very thin metal sheet... exactly the size of the square. Place the sheet around the hole and go to down shaving it down.
Just an idea to help protect the surrounding area.
1992 Trans Am
May 10, 2023 07:19 PM
sreZ28
Aug 14, 2015 07:48 PM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
