Need to replace cluster clear cover
Old Nov 21, 2006 | 11:06 AM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I have a 140mph cluster in my Trans Am and the clear lens cover is broken. Do I need to find one from a 140mph cluster, or is the clear lens from the 120mph cluster the same?
Old Nov 21, 2006 | 12:00 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Should be the same. Ide try to get one as close in year as you can... Im not sure if they will ALL fit. But most should. They are easy to change out.
Just curious...how the heck did you manage to crack that plastic piece??
Justin
Old Nov 22, 2006 | 08:53 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Mine was broken when I bought my car...no idea how someone does something like this. At any rate, the lenses are the same from 1985-92, with the exception of the extremely poorly-optioned base models that only have the lens over two gauges, the rest of the instrumentation being comprised of idiot lights.
Old May 31, 2008 | 11:54 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: Need to replace cluster clear cover
Does anyone know of a dealer / vendor that sells the new replacment clear lens cover? Anybody have a GM part number handy?
Also was there some models w/o a trip odometer built into the speedomemter? Mine has it and I wanted to make sure the lens cover had the provision for the **** to stick through.
Old May 31, 2008 | 01:02 PM
navy02ws6's Avatar
I doubt this part is available new anywhere, except perhaps from a dealer as the entire gauge cluster assembly which would not be very cost-effective. I got mine from a junkyard, then took it home and polished it with a Mother's Ball and plastic polish. Looks brand new!
Old Jun 7, 2008 | 06:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I don't have the part number handy, but I believe that GM does list a part number for the lens, and I looked it up due to the lower part of my speedo lens being broke. IIRC, they wanted like $100 or something for just the LENS, which I figure is kind of ridiculous. Best bet would be a junkyard, as was said above.
Old Jun 7, 2008 | 08:48 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Keep your eyes open. I have seen clusters sold "as is" on ebay pretty cheap. Maybe call bruce at Hawk's and see if he has a broken cluster sitting around. They are pretty easy to work with and can sometimes find stuff not cataloged on their website. Put a posting on here saying something like Cluster wanted-don't care if it works. i'm sure somebody will come through for you.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Dec 31, 2015 04:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
