broke steering column need an opinion
Old Dec 14, 2006 | 09:18 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
my steering wheel column is coming loose again and is starting to woble idk what you call it but to fix it you have to completely tear down the column and put locktight on the bolts in the back. it happend about a year ago and we got it fixed at a shop, well it is doing it again. do you think i should just replace the whole column or fix it again? i dont want it to keep breaking like this b/c it is pretty dangerous to drive b/c when you turn the whole column moves to the side.
Old Dec 14, 2006 | 01:20 PM
tj willy's Avatar
Car: 87 IROC Z
Engine: LB9
Axle/Gears: Positrac - 3.23's
I say replace it. Unless you want to do it again in a year. Sounds like the first fix was more of a patch than anything. I just spoke with a guy that has some right now. Very nice and very reasonably priced.
I will pm his email to you.
I think he works by word of mouth mostly so you can tell him Phil from Louisiana sent you. I know he is located in PA.
Hope that helps.
Old Jan 1, 2007 | 10:53 AM
Pat Hall's Avatar
The problem with replacing it with another steering column is that ALL tilt columns eventually have this problem. If you end up paying a mechanic to fix yours again, even if you have to stand over his shoulder while he's doing it, make sure he uses the high-strength "red" loctite on all 4 bolts and that he tightens the **** outta them. A lot of repair shops use lower strength threadlocker or none at all, which guarantees it'll come loose again eventually. The shop I used to work at used the red loctite on the screws and we never had one come back loose again.
Old Jan 1, 2007 | 02:28 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
I've got two sitting in the back of a car right now, both with keys- one tilt one without. You feel like driving to Atlanta?
Old Jan 2, 2007 | 08:00 AM
LB3's Avatar
LB3
Car: 1987 IROC
Engine: Built 350 TPI
replacing it will not help the problem will still be their. It will happen with the new one too. I'ts not really hard to fix yourself.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
