Sagging Sun Visors - What are my options?
Old Jan 5, 2007 | 10:52 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Well somehow my sun visors are sagging but my headliner is good. What are my options?
I know Jim85Iroc sells replacement visors and I could probably get them recovered at an upholstery shop.
If I have them recovered, does anyone sell cloth or vinyl that is a dead match for the material in my car?
If I go with a replacement, how closely does the material match the stock stuff?
Thanks!
Bill
Old Jan 6, 2007 | 11:24 AM
RedLava's Avatar
Car: 86 z28
I would personally get some out of a 4th gen. The ones I got were reasonably priced compared to everything else around here in the junk yards, and they look great.
Old Jan 6, 2007 | 11:26 AM
wgripp's Avatar
are they a bolt in swap or what?
Old Jan 7, 2007 | 05:02 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
hope this helps.I've tried to swap out sunvisors in other rides b4 and learned that sometimes(sometimes)even from yr to yr the part that screws in alighns differently.But once i had a collection i started to disect them.The flat part comes off the pivot piece and ya can swap them out.I ended up putting some nice ones from a caddy with those slide out xtensions and lighted vanity mirror in my daughters olds sutlass supreme.Thnikin of doin same for my R/S.
Old Jan 8, 2007 | 12:19 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
I took a small piece of house siding ( or any other bendable plastic) and wraped that around the metal shaft that goes inside the actual visor from the mount. The other piece of plastic in there was all torn to hell, and i had to remove that. It took some tooling around with but eventually i got everything to fit ect. and works as good as new.
Old Jan 12, 2007 | 12:20 AM
RedLava's Avatar
Car: 86 z28
the ones i got out of the 4th gen bolted right in for me no modding necessary. they had the same triangle shape attachment.
Old Jan 13, 2007 | 12:25 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I went to fabric shop & bought headliner material that matches the OEM.I redid my headliner,visors,T-top shades.This was about 11 years ago.Visors & the rest are still holding up.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
